Samsung BD-F5700 Power Cord Replacement
    1. Samsung BD-F5700 Power Cord Replacement, Power Cord: step 1, image 1 of 3 Samsung BD-F5700 Power Cord Replacement, Power Cord: step 1, image 2 of 3 Samsung BD-F5700 Power Cord Replacement, Power Cord: step 1, image 3 of 3
      • Use Phillips 0 Screwdriver to remove two (2), 10 mm rear screws.
      • Use the iFixit opening tool to help separate the top plastic casing from the bottom metal casing.
      • When opening the device, be careful to not damage the ribbon cable circled in image 3.
      Ask FixBot
    2. Samsung BD-F5700 Power Cord Replacement: step 2, image 1 of 3 Samsung BD-F5700 Power Cord Replacement: step 2, image 2 of 3 Samsung BD-F5700 Power Cord Replacement: step 2, image 3 of 3
      • Use Phillips 0 screwdriver to remove two (2), 10 mm screws from the plastic cover.
      • Remove plastic cover from board.
      Ask FixBot
    3. Samsung BD-F5700 Power Cord Replacement: step 3, image 1 of 2 Samsung BD-F5700 Power Cord Replacement: step 3, image 2 of 2
      • Pull upward on back of the black and white wire to dislocate the black tab piece from device.
      • To remove the cord from the device entirely, press on the white tab in the device and gently pull.
      Ask FixBot
    4. Samsung BD-F5700 Power Cord Replacement: step 4, image 1 of 1
      • Insert the iFixit Opening tool into the black tab on the power cord, and use leverage to open the black tab.
      • Pull the tab off the wire so that it can be placed on the replacement cord.
      Ask FixBot
Nicholas Straits
236 Reputation
1 Guide authored
USF Tampa, Team S16-G4, Boczar Spring 2018 Member of USF Tampa, Team S16-G4, Boczar Spring 2018
USFT-BOCZAR-S18S16G4
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 621
