Samsung BD-E5400 Disk Drive Replacement
  1. Samsung BD-E5400 Disk Drive Replacement, Outer Cover: step 1, image 1 of 2 Samsung BD-E5400 Disk Drive Replacement, Outer Cover: step 1, image 2 of 2
    • Remove the two 10mm Phillips #1 screws.
    • Remove the one 8 mm Phillips #1 screw.
    • Carefully lift up the cover and lay back, to ensure that you do not damage the attached cable.
    Ask FixBot
  2. Samsung BD-E5400 Disk Drive Replacement: step 2, image 1 of 1
    • Unplug the small wiring bundle attaching the body of the device to the cover.
    • Lay the cover aside.
    Ask FixBot
  3. Samsung BD-E5400 Disk Drive Replacement, Disk Drive: step 3, image 1 of 2 Samsung BD-E5400 Disk Drive Replacement, Disk Drive: step 3, image 2 of 2
    • Remove both wire bundles from motherboard.
    • Depress tabs located on each side of disk drive as shown.
    Ask FixBot
  4. Samsung BD-E5400 Disk Drive Replacement: step 4, image 1 of 1
    • Push entire disk drive forward.
    • Remove disk drive and replace.
    Ask FixBot
Jeremy Estrella
100 Reputation
1 Guide authored
IUPUI, Team S1-G3, Arle Fall 2018 Member of IUPUI, Team S1-G3, Arle Fall 2018
IUPUI-ARLE-F18S1G3
3 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 32
All Time: 1,036
