Samsung BD-D5500 Drive Lens Replacement
  1. Samsung BD-D5500 Drive Lens Replacement, Samsung BD-D5500 Disassembly: step 1, image 1 of 1
    • To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
    Ask FixBot
  2. Samsung BD-D5500 Drive Lens Replacement: step 2, image 1 of 2 Samsung BD-D5500 Drive Lens Replacement: step 2, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the screw that attaches the top cover to the rear of the device. This will allow you to remove the cover.
    • This is how your device will look after you remove the top.
    Ask FixBot
  3. Samsung BD-D5500 Drive Lens Replacement, Disc Drive: step 3, image 1 of 1
    • Please locate your disc drive
    • Your disc drive should look like the one pictured. If your disc drive does not look as follows please confirm that you are looking at the right guide.
    Ask FixBot
  4. Samsung BD-D5500 Drive Lens Replacement: step 4, image 1 of 1
    • Once you have located your disc drive it is time to remove the drive
    • You will see four silver 1.1mm Phillips #2 screws located on each corner of the disc drive.
    Ask FixBot
  5. Samsung BD-D5500 Drive Lens Replacement: step 5, image 1 of 2 Samsung BD-D5500 Drive Lens Replacement: step 5, image 2 of 2
    • Once you have removed the four screws using a Phillips #2 screwdriver you are now able to take out the disc drive
    • Carefully remove the disc drive being sure not to disrupt anything else in the Blu-Ray player.
    • This is how your disc drive should look if you have removed it from the player correctly.
    Ask FixBot
  6. Samsung BD-D5500 Drive Lens Replacement, Drive Lens: step 6, image 1 of 1
    • Unhook the wire from the drive lens by flipping the black piece up and pulling the wire out, at the area marked.
    Ask FixBot
  7. Samsung BD-D5500 Drive Lens Replacement: step 7, image 1 of 1
    • Unhook the left bar in the area circled by pushing the bar to the left, lifting up and then pushing to the right.
    • Make sure the drive lens is pushed back toward the black wheel, as indicated with the big red square.
    Ask FixBot
  8. Samsung BD-D5500 Drive Lens Replacement: step 8, image 1 of 1
    • Slide the Drive Lens up the little metal pole until it is released.
    • This is how the drive lens should look once it is removed.
    Ask FixBot
Anthony Gerardi
100 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 49
All Time: 1,469
