Samsung BD-D5500 Disc Tray Replacement
    1. Samsung BD-D5500 Disc Tray Replacement, Samsung BD-D5500 Disassembly: step 1, image 1 of 1
      • To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
      Ask FixBot
    2. Samsung BD-D5500 Disc Tray Replacement: step 2, image 1 of 2 Samsung BD-D5500 Disc Tray Replacement: step 2, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the screw that attaches the top cover to the rear of the device. This will allow you to remove the cover.
      • This is how your device will look after you remove the top.
      Ask FixBot
    1. Samsung BD-D5500 Disc Tray Replacement, Disc Tray: step 3, image 1 of 1
      • To remove the disc hub all you have to do is remove the 4 screws holding it down.
      Ask FixBot
    2. Samsung BD-D5500 Disc Tray Replacement: step 4, image 1 of 1
      • To replace the disc tray open the disk hub and unsnap the sides of the device.
      Ask FixBot
    3. Samsung BD-D5500 Disc Tray Replacement: step 5, image 1 of 1
      • Locate the slider that reads open and close.
      • To open the disc tray slide it to the side that says open.
      Ask FixBot
    4. Samsung BD-D5500 Disc Tray Replacement: step 6, image 1 of 1
      • Return it face up and the disc tray will slide out.
      Ask FixBot
Brandon Nelson
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 44
All Time: 1,643
