Samsung BD-D5500 Disc Drive Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
0
Past 7 Days:
9
Past 30 Days:
73
All Time:
1,482
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
Before you begin this guide you will need to refer to the guide on how to take the top off of the device. Once you have completed that you can begin removing your disc drive.
Tools
    1. Samsung BD-D5500 Disc Drive Replacement, Samsung BD-D5500 Disassembly: step 1, image 1 of 1
      • To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
      Ask FixBot
    2. Samsung BD-D5500 Disc Drive Replacement: step 2, image 1 of 2 Samsung BD-D5500 Disc Drive Replacement: step 2, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the screw that attaches the top cover to the rear of the device. This will allow you to remove the cover.
      • This is how your device will look after you remove the top.
      Ask FixBot
    1. Samsung BD-D5500 Disc Drive Replacement, Disc Drive: step 3, image 1 of 1
      • Please locate your disc drive
      • Your disc drive should look like the one pictured. If your disc drive does not look as follows please confirm that you are looking at the right guide.
      Ask FixBot
    2. Samsung BD-D5500 Disc Drive Replacement: step 4, image 1 of 1
      • Once you have located your disc drive it is time to remove the drive
      • You will see four silver 1.1mm Phillips #2 screws located on each corner of the disc drive.
      Ask FixBot
    3. Samsung BD-D5500 Disc Drive Replacement: step 5, image 1 of 2 Samsung BD-D5500 Disc Drive Replacement: step 5, image 2 of 2
      • Once you have removed the four screws using a Phillips #2 screwdriver you are now able to take out the disc drive
      • Carefully remove the disc drive being sure not to disrupt anything else in the Blu-Ray player.
      • This is how your disc drive should look if you have removed it from the player correctly.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 73
All Time: 1,482
