Samsung Alias 2 Motherboard Replacement
    1. Samsung Alias 2 Motherboard Replacement, Battery: step 1, image 1 of 1
      • Press down on the back cover of the phone and remove it.
      Ask FixBot
    2. Samsung Alias 2 Motherboard Replacement: step 2, image 1 of 1
      • Take out the battery from the device.
      Ask FixBot
    1. Samsung Alias 2 Motherboard Replacement, Motherboard: step 3, image 1 of 1
      • Use a Phillips screwdriver to remove the four 4.2 mm screws from the four corners of the battery slot.
      Ask FixBot
    2. Samsung Alias 2 Motherboard Replacement: step 4, image 1 of 1
      • Use a plastic opening tool to peel off the Verizon logo tab from the top of the back cover.
      • The tab is secured with glue, so peel it off gently.
      Ask FixBot
    3. Samsung Alias 2 Motherboard Replacement: step 5, image 1 of 1
      • Remove the three 4.3 mm screws that are now exposed using a Phillips screwdriver.
      Ask FixBot
    4. Samsung Alias 2 Motherboard Replacement: step 6, image 1 of 1
      • Use the plastic opening tool to remove the back outside casing.
      • Be careful not to lose the side buttons, as they may come off when removing the casing.
      Ask FixBot
    5. Samsung Alias 2 Motherboard Replacement: step 7, image 1 of 1
      • Gently pull up the yellow tab to prepare for disconnecting components.
      Ask FixBot
    6. Samsung Alias 2 Motherboard Replacement: step 8, image 1 of 1
      • Use tweezers to disconnect the connecting cord.
      Ask FixBot
    7. Samsung Alias 2 Motherboard Replacement: step 9, image 1 of 1
      • Disconnect the rectangular ribbon cable by carefully pulling it out of its connector.
      Ask FixBot
    8. Samsung Alias 2 Motherboard Replacement: step 10, image 1 of 1
      • Carefully lift and remove the logic board from the device.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Chris
133 Reputation
5 Guides authored
Cal Poly, Team 12-35, Maness Spring 2011 Member of Cal Poly, Team 12-35, Maness Spring 2011
CPSU-MANESS-S11S12G35
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 19
All Time: 3,199
