Up to 20% off select tools
Samsung Alias 2 Camera Replacement
Views: 3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
93
All Time:
2,968
Comments: 0
Go to guide comments
Completed: 0
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Tools
Introduction
Go to step 1 ↓
This guide shows you how to remove a broken camera and install a new camera.
    1. Samsung Alias 2 Camera Replacement, Battery: step 1, image 1 of 1
      • Press down on the back cover of the phone and remove it.
      Ask FixBot
    2. Samsung Alias 2 Camera Replacement: step 2, image 1 of 1
      • Take out the battery from the device.
      Ask FixBot
    1. Samsung Alias 2 Camera Replacement, Camera: step 3, image 1 of 1
      • Remove the (2) 4.1 mm screws on screen.
      Ask FixBot
    2. Samsung Alias 2 Camera Replacement: step 4, image 1 of 3 Samsung Alias 2 Camera Replacement: step 4, image 2 of 3 Samsung Alias 2 Camera Replacement: step 4, image 3 of 3
      • Remove front outside casing with plastic opening tools.
      Ask FixBot
    3. Samsung Alias 2 Camera Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to remove the camera from its holding slot.
      Ask FixBot
    4. Samsung Alias 2 Camera Replacement: step 6, image 1 of 1
      • Use a plastic opening tool to lift the tab that holds the camera ribbon in place.
      Ask FixBot
    5. Samsung Alias 2 Camera Replacement: step 7, image 1 of 1
      • Use tweezers to remove the camera.
      Ask FixBot
    6. Samsung Alias 2 Camera Replacement: step 8, image 1 of 1
      • Slide ribbon of new camera under the same tab.
      Ask FixBot
    7. Samsung Alias 2 Camera Replacement: step 9, image 1 of 1
      • Close the tab down onto the new camera ribbon.
      Ask FixBot
    8. Samsung Alias 2 Camera Replacement: step 10, image 1 of 1
      • Use tweezers to put the new camera into the camera slot that previously held the old camera.
      • WARNING: Do not touch the camera lens as it will easily scratch or smudge.
      Ask FixBot
Author
with
Chris
133 Reputation
5 Guides authored
Cal Poly, Team 12-35, Maness Spring 2011 Member of Cal Poly, Team 12-35, Maness Spring 2011
CPSU-MANESS-S11S12G35
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 93
All Time: 2,968
