Samsung Admire Speaker Replacement
    1. Samsung Admire Speaker Replacement, Back Cover: step 1, image 1 of 1
      • Use your fingernail or plastic opening tool to pull up the back cover of the phone from under the slit.
      Ask FixBot
    2. Samsung Admire Speaker Replacement, Remove the battery: step 2, image 1 of 1
      • Carefully remove the battery by placing your fingernail underneath the hole and pulling out the battery.
      • Your hands should not be wet.
      Ask FixBot
    3. Samsung Admire Speaker Replacement, Remove the screws: step 3, image 1 of 3 Samsung Admire Speaker Replacement, Remove the screws: step 3, image 2 of 3 Samsung Admire Speaker Replacement, Remove the screws: step 3, image 3 of 3
      • Use the Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
      Ask FixBot
    4. Samsung Admire Speaker Replacement, Inside back cover: step 4, image 1 of 3 Samsung Admire Speaker Replacement, Inside back cover: step 4, image 2 of 3 Samsung Admire Speaker Replacement, Inside back cover: step 4, image 3 of 3
      • Use the plastic opening tools to remove the inside back cover.
      • Place the plastic opening tools on the outside rim of the inside back cover.
      • Carefully lift the cover and circle around the rim to open the inside back cover completely.
      • Carefully disconnect ribbon cables and slowly lift the inside back cover to remove it.
      Ask FixBot
    5. Samsung Admire Speaker Replacement, Speaker: step 5, image 1 of 2 Samsung Admire Speaker Replacement, Speaker: step 5, image 2 of 2
      • The speaker is located within the inside of the back cover.
      • Simply remove it by lifting it off with the plastic opening tool.
      Ask FixBot
2 other people completed this guide.
Thao Uyen Do
944 Reputation
4 Guides authored
USF Tampa, Team 7-5, Remmell Winter 2015 Member of USF Tampa, Team 7-5, Remmell Winter 2015
USFT-REMMELL-W15S7G5
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 30
Past 30 Days: 109
All Time: 1,321
