Samsung Admire Motherboard Replacement
    1. Samsung Admire Motherboard Replacement, Back Cover: step 1, image 1 of 1
      • To open the back cover of the phone, use your fingernail or plastic opening tool under the slit to pull the cover up.
      Ask FixBot
    2. Samsung Admire Motherboard Replacement, Remove Battery: step 2, image 1 of 1
      • Carefully remove the battery by placing your fingernail underneath the hole and pull out the battery.
      • Your hands should not be wet.
      Ask FixBot
    3. Samsung Admire Motherboard Replacement, Remove the screws: step 3, image 1 of 3 Samsung Admire Motherboard Replacement, Remove the screws: step 3, image 2 of 3 Samsung Admire Motherboard Replacement, Remove the screws: step 3, image 3 of 3
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Use the Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
      • Be careful not to lose the screws, so place them on a magnetic mat.
      Ask FixBot
    4. Samsung Admire Motherboard Replacement, Inside back cover: step 4, image 1 of 3 Samsung Admire Motherboard Replacement, Inside back cover: step 4, image 2 of 3 Samsung Admire Motherboard Replacement, Inside back cover: step 4, image 3 of 3
      • Use the Plastic Opening tools to remove the inside back cover.
      • Place the Plastic Opening tools on the outside rim of the inside back cover.
      • Carefully lift the cover and circle around the rim to open the inside back cover completely.
      • Carefully disconnect ribbon cables and slowly lift the inside back cover to remove it.
      Ask FixBot
    5. Samsung Admire Motherboard Replacement, Motherboard: step 5, image 1 of 3 Samsung Admire Motherboard Replacement, Motherboard: step 5, image 2 of 3 Samsung Admire Motherboard Replacement, Motherboard: step 5, image 3 of 3
      • Lift the motherboard slowly.
      • Carefully disconnect the volume button away from the motherboard.
      • Disconnect the two ribbon cables from the back of the motherboard.
      • Remove the motherboard completely from the phone
      Ask FixBot
11 other people completed this guide.
Thao Uyen Do
944 Reputation
4 Guides authored
USF Tampa, Team 7-5, Remmell Winter 2015 Member of USF Tampa, Team 7-5, Remmell Winter 2015
USFT-REMMELL-W15S7G5
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 106
All Time: 1,946
