Up to 20% off select tools
Samsung Admire Camera Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
108
All Time:
2,476
Comments: 0
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide shows you how to replace the camera on your phone.
    1. Samsung Admire Camera Replacement, Back Cover: step 1, image 1 of 1
      • Use your fingernail or the plastic opening tool under the slit to pull the back cover off.
      Ask FixBot
    2. Samsung Admire Camera Replacement, Remove the Battery: step 2, image 1 of 1
      • Making sure your hands are dry, insert your fingernail beneath the battery and remove it.
      Ask FixBot
    3. Samsung Admire Camera Replacement, Remove the screws: step 3, image 1 of 3 Samsung Admire Camera Replacement, Remove the screws: step 3, image 2 of 3 Samsung Admire Camera Replacement, Remove the screws: step 3, image 3 of 3
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Use a Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
      • Place the screws on a magnetic mat to prevent losing them.
      Ask FixBot
    4. Samsung Admire Camera Replacement, Inside back Cover: step 4, image 1 of 3 Samsung Admire Camera Replacement, Inside back Cover: step 4, image 2 of 3 Samsung Admire Camera Replacement, Inside back Cover: step 4, image 3 of 3
      • Place the Plastic Opening tool on the outside rim of the back cover.
      • Carefully circle around the rim to open the inside back cover completely.
      • Disconnect the ribbon cables and remove the back cover.
      Ask FixBot
    5. Samsung Admire Camera Replacement, Motherboard: step 5, image 1 of 3 Samsung Admire Camera Replacement, Motherboard: step 5, image 2 of 3 Samsung Admire Camera Replacement, Motherboard: step 5, image 3 of 3
      • Carefully disconnect the volume button, the microphone connector, and the screen connector from the motherboard.
      • Pull back the side clips and lift the motherboard slowly.
      Ask FixBot
    6. Samsung Admire Camera Replacement, Camera: step 6, image 1 of 2 Samsung Admire Camera Replacement, Camera: step 6, image 2 of 2
      • Use the plastic opening tool to disconnect the camera from the phone.
      • Connect the new camera into the motherboard.
      Ask FixBot
12 other people completed this guide.
Author
with
Thao Uyen Do
944 Reputation
4 Guides authored
USF Tampa, Team 7-5, Remmell Winter 2015 Member of USF Tampa, Team 7-5, Remmell Winter 2015
USFT-REMMELL-W15S7G5
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 108
All Time: 2,476
