Up to 20% off select tools
Samsung Ace Casing Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
98
All Time:
1,462
Comments: 0
Go to guide comments
Completed: 0
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
If your current case is damaged, this guide will help you install a new case to protect your phone from further abuse.
    1. Samsung Ace Casing Replacement, Battery: step 1, image 1 of 3 Samsung Ace Casing Replacement, Battery: step 1, image 2 of 3 Samsung Ace Casing Replacement, Battery: step 1, image 3 of 3
      • To remove the back casing, firmly press down and push towards the bottom of the phone.
      Ask FixBot
    2. Samsung Ace Casing Replacement: step 2, image 1 of 1
      • With the casing removed, lift the battery from the indicated indentation.
      Ask FixBot
    3. Samsung Ace Casing Replacement: step 3, image 1 of 1
      • From here, you can now access the SIM card and model/serial numbers.
      Ask FixBot
    1. Samsung Ace Casing Replacement, Casing: step 4, image 1 of 1
      • Using the Phillips #00 screwdriver, remove the four indicated screws (4.5 mm).
      Ask FixBot
    2. Samsung Ace Casing Replacement: step 5, image 1 of 2 Samsung Ace Casing Replacement: step 5, image 2 of 2
      • Press the pointed edge of the spudger into the side of the two rubber plugs in order to lift and remove them from the top of the phone.
      • Then, using the Phillips #00 screwdriver, remove the two indicated Phillip screws (6.5 mm).
      Ask FixBot
    3. Samsung Ace Casing Replacement: step 6, image 1 of 1
      • To remove the SIM card, start by pressing the top of the card and push down and away towards the bottom of the phone. Then, as indicated, pull the SIM card out.
      Ask FixBot
    4. Samsung Ace Casing Replacement: step 7, image 1 of 2 Samsung Ace Casing Replacement: step 7, image 2 of 2
      • Begin to slowly lift the back casing of the phone. You should hear a snap when the casing is released.
      • The power, volume, and camera buttons may fall out when separating the front and back casing.
      Ask FixBot
    5. Samsung Ace Casing Replacement: step 8, image 1 of 1
      • Your casing should be separated and the three loose buttons put to the side.
      • Be aware of the wiring on the top of the phone. Make sure not to pull it apart when separating the case.
      Ask FixBot
    6. Samsung Ace Casing Replacement: step 9, image 1 of 2 Samsung Ace Casing Replacement: step 9, image 2 of 2
      • Slowly remove the back casing by gently pulling the ribbon connection.
      Ask FixBot
    7. Samsung Ace Casing Replacement: step 10, image 1 of 2 Samsung Ace Casing Replacement: step 10, image 2 of 2
      • Gently pull on the wires to remove the front casing.
      Ask FixBot
    8. Samsung Ace Casing Replacement: step 11, image 1 of 1
      • Your front casing and front speaker are now released.
      Ask FixBot
Author
with
Breanne
187 Reputation
5 Guides authored
Cal Poly, Team 6-24, Amido Spring 2012 Member of Cal Poly, Team 6-24, Amido Spring 2012
CPSU-AMIDO-S12S6G24
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 98
All Time: 1,462
