Samsung Ace Back Speakers Replacement
    1. Samsung Ace Back Speakers Replacement, Battery: step 1, image 1 of 3 Samsung Ace Back Speakers Replacement, Battery: step 1, image 2 of 3 Samsung Ace Back Speakers Replacement, Battery: step 1, image 3 of 3
      • To remove the back casing, firmly press down and push towards the bottom of the phone.
      Ask FixBot
    2. Samsung Ace Back Speakers Replacement: step 2, image 1 of 1
      • With the casing removed, lift the battery from the indicated indentation.
      Ask FixBot
    3. Samsung Ace Back Speakers Replacement: step 3, image 1 of 1
      • From here, you can now access the SIM card and model/serial numbers.
      Ask FixBot
    1. Samsung Ace Back Speakers Replacement, Casing: step 4, image 1 of 1
      • Using the Phillips #00 screwdriver, remove the four indicated screws (4.5 mm).
      Ask FixBot
    2. Samsung Ace Back Speakers Replacement: step 5, image 1 of 2 Samsung Ace Back Speakers Replacement: step 5, image 2 of 2
      • Press the pointed edge of the spudger into the side of the two rubber plugs in order to lift and remove them from the top of the phone.
      • Then, using the Phillips #00 screwdriver, remove the two indicated Phillip screws (6.5 mm).
      Ask FixBot
    3. Samsung Ace Back Speakers Replacement: step 6, image 1 of 1
      • To remove the SIM card, start by pressing the top of the card and push down and away towards the bottom of the phone. Then, as indicated, pull the SIM card out.
      Ask FixBot
    4. Samsung Ace Back Speakers Replacement: step 7, image 1 of 2 Samsung Ace Back Speakers Replacement: step 7, image 2 of 2
      • Begin to slowly lift the back casing of the phone. You should hear a snap when the casing is released.
      • The power, volume, and camera buttons may fall out when separating the front and back casing.
      Ask FixBot
    5. Samsung Ace Back Speakers Replacement: step 8, image 1 of 1
      • Your casing should be separated and the three loose buttons put to the side.
      • Be aware of the wiring on the top of the phone. Make sure not to pull it apart when separating the case.
      Ask FixBot
    6. Samsung Ace Back Speakers Replacement: step 9, image 1 of 2 Samsung Ace Back Speakers Replacement: step 9, image 2 of 2
      • Slowly remove the back casing by gently pulling the ribbon connection.
      Ask FixBot
    7. Samsung Ace Back Speakers Replacement: step 10, image 1 of 2 Samsung Ace Back Speakers Replacement: step 10, image 2 of 2
      • Gently pull on the wires to remove the front casing.
      Ask FixBot
    8. Samsung Ace Back Speakers Replacement: step 11, image 1 of 1
      • Your front casing and front speaker are now released.
      Ask FixBot
    1. Samsung Ace Back Speakers Replacement, Back Speakers: step 12, image 1 of 1
      • Locate the back speaker.
      Ask FixBot
    2. Samsung Ace Back Speakers Replacement: step 13, image 1 of 1
      • Use the flat edge of the spudger to gently pry and remove the speaker.
      Ask FixBot
Breanne
187 Reputation
5 Guides authored
Cal Poly, Team 6-24, Amido Spring 2012 Member of Cal Poly, Team 6-24, Amido Spring 2012
CPSU-AMIDO-S12S6G24
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 22
All Time: 1,229
