Samsung ATIV Book 9 Plus Wi-Fi Card Replacement
  1. Samsung ATIV Book 9 Plus Wi-Fi Card Replacement, Back Cover: step 1, image 1 of 3 Samsung ATIV Book 9 Plus Wi-Fi Card Replacement, Back Cover: step 1, image 2 of 3 Samsung ATIV Book 9 Plus Wi-Fi Card Replacement, Back Cover: step 1, image 3 of 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Wi-Fi Card Replacement: step 2, image 1 of 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Wi-Fi Card Replacement, Wi-Fi Card: step 3, image 1 of 1
    • Gently pull off both cables attached to Wi-Fi card.
  4. Samsung ATIV Book 9 Plus Wi-Fi Card Replacement: step 4, image 1 of 1
    • Unscrew the labeled screw using a Phillips #000 screwdriver.
  5. Samsung ATIV Book 9 Plus Wi-Fi Card Replacement: step 5, image 1 of 1
    • Pull Wi-Fi card out to completely detach it.
Ryan Smith
193 Reputation
2 Guides authored
IUPUI, Team S7-G7, Wilson Spring 2019 Member of IUPUI, Team S7-G7, Wilson Spring 2019
IUPUI-WILSON-S19S7G7
3 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 31
All Time: 992
