Samsung ATIV Book 9 Plus Keys Replacement
    1. Samsung ATIV Book 9 Plus Keys Replacement, Keys: step 1, image 1 of 2 Samsung ATIV Book 9 Plus Keys Replacement, Keys: step 1, image 2 of 2
      • Open your laptop so your keyboard is facing you and is easily accessible.
      Ask FixBot
    2. Samsung ATIV Book 9 Plus Keys Replacement: step 2, image 1 of 3 Samsung ATIV Book 9 Plus Keys Replacement: step 2, image 2 of 3 Samsung ATIV Book 9 Plus Keys Replacement: step 2, image 3 of 3
      • Using a plastic opening tool, carefully push the thin tip under the key.
      Ask FixBot
    3. Samsung ATIV Book 9 Plus Keys Replacement: step 3, image 1 of 2 Samsung ATIV Book 9 Plus Keys Replacement: step 3, image 2 of 2
      • Pivot the tool upwards. This should pry the key away from the keyboard.
      • Hearing some snapping sounds should be normal as the key lifts away from its attachments.
      • Continue lifting the tool until the key comes away completely or gently pull the key off. Repeat for other keys as needed.
      • Be gentle, as the attachments may accidentally break with rough handling.
      Ask FixBot
3 other people completed this guide.
unknown
261 Reputation
1 Guide authored
Baylor, Team 2-3, Grigsby Spring 2015 Member of Baylor, Team 2-3, Grigsby Spring 2015
BU-GRIGSBY-S15S2G3
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 93
All Time: 6,730
