Samsung ATIV Book 9 Plus Internal Fans Replacement
    1. Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: step 1, image 1 of 3 Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: step 1, image 2 of 3 Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: step 1, image 3 of 3
      • Turn the laptop upside down so that the underside of the laptop is facing you.
      • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
      Ask FixBot
    2. Samsung ATIV Book 9 Plus Internal Fans Replacement: step 2, image 1 of 1
      • Lift the cover to reveal the interior of the laptop.
      Ask FixBot
    1. Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: step 3, image 1 of 3 Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: step 3, image 2 of 3 Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: step 3, image 3 of 3
      • The fans should be in the upper left corner of the laptop if the laptop is oriented with the battery in the bottom half.
      • Gently lift the fans' black connector strip out of the way.
      Ask FixBot
    2. Samsung ATIV Book 9 Plus Internal Fans Replacement: step 4, image 1 of 2 Samsung ATIV Book 9 Plus Internal Fans Replacement: step 4, image 2 of 2
      • Using a Phillips head screwdriver, unscrew four 4.55 mm Phillips #000 screws that bind the fans.
      Ask FixBot
    3. Samsung ATIV Book 9 Plus Internal Fans Replacement: step 5, image 1 of 1
      • Disconnect the white connectors by gently tugging on them.
      • Lift the fans from their positions.
      Ask FixBot
2 other people completed this guide.
Rhannie Surel
137 Reputation
1 Guide authored
Baylor, Team 2-3, Grigsby Spring 2015 Member of Baylor, Team 2-3, Grigsby Spring 2015
BU-GRIGSBY-S15S2G3
4 Members
48 Guides authored
1 Guide Comment
I think that's to easy!
Ocean - Reply Share
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 101
All Time: 5,048
