Samsung ATIV Book 4 Battery Replacement
    1. Samsung ATIV Book 4 Battery Replacement, Battery: step 1, image 1 of 2 Samsung ATIV Book 4 Battery Replacement, Battery: step 1, image 2 of 2
      • Place the computer upside down.
      • Remove 2 rubber pads, by prying up on them.
      • There may be adhesive holding them down. If this is the case, the plastic opening tool may be needed to remove them.
      • Remove the seven 6.5mm screws on exterior of computer.
      Ask FixBot
    2. Samsung ATIV Book 4 Battery Replacement: step 2, image 1 of 2 Samsung ATIV Book 4 Battery Replacement: step 2, image 2 of 2
      • Remove the panel by sliding it down and lifting it away from the computer.
      • Remove the four 4.4mm screws that are underneath the panel.
      • Remove the two 6.5mm screws that were underneath the rubber pads.
      Ask FixBot
    3. Samsung ATIV Book 4 Battery Replacement: step 3, image 1 of 2 Samsung ATIV Book 4 Battery Replacement: step 3, image 2 of 2
      • Using the plastic opening tool, pry plastic panel away from computer.
      • Start prying at one point and work your way around the entire computer until panel is free come computer.
      • Remove the panel from computer, once all tabs are broken free.
      Ask FixBot
    4. Samsung ATIV Book 4 Battery Replacement: step 4, image 1 of 1
      • Remove the four 3.5mm screws holding the battery.
      • Peel back the tape securing the wires to the battery.
      • Lift and remove the battery from its location.
      • Don't pull/tear the wires connected to battery harness.
      Ask FixBot
    5. Samsung ATIV Book 4 Battery Replacement: step 5, image 1 of 1
      • Disconnect the battery harness from computer.
      • Completely remove the battery and replace it.
      Ask FixBot
    6. Samsung ATIV Book 4 Battery Replacement: step 6, image 1 of 1
      • Plug battery harness back in.
      • Assure the wires are pointed up (towards you) then plugging back in, as shown.
      Ask FixBot
4 other people completed this guide.
Chad
443 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 29
Past 30 Days: 124
All Time: 10,849
