Samsung AH59-02408A Motherboard Replacement
  1. Samsung AH59-02408A Motherboard Replacement, Motherboard: step 1, image 1 of 3 Samsung AH59-02408A Motherboard Replacement, Motherboard: step 1, image 2 of 3 Samsung AH59-02408A Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Separate the front and back case with your hands. Grip it by the seam and open it up gently.
  2. Samsung AH59-02408A Motherboard Replacement: step 2, image 1 of 3 Samsung AH59-02408A Motherboard Replacement: step 2, image 2 of 3 Samsung AH59-02408A Motherboard Replacement: step 2, image 3 of 3
    • Identify whether the circuit board is secured to the keypad or the back plate.
    • Pull out the circuit board from the sockets in the back case.
  3. Samsung AH59-02408A Motherboard Replacement: step 3, image 1 of 3 Samsung AH59-02408A Motherboard Replacement: step 3, image 2 of 3 Samsung AH59-02408A Motherboard Replacement: step 3, image 3 of 3
    • Remove the circuit board connectors from the keypad.
  4. Samsung AH59-02408A Motherboard Replacement: step 4, image 1 of 3 Samsung AH59-02408A Motherboard Replacement: step 4, image 2 of 3 Samsung AH59-02408A Motherboard Replacement: step 4, image 3 of 3
    • To complete the replacement, follow the steps in reverse order using your new circuit board.
    • Ensure that your Circuit Board's LED bulb is inserted into your front plate's socket as labelled. Otherwise your remote will not function.
Ferose Hameed
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 69
All Time: 1,835
