Samsung 500C ChromeBook CPU Fan Replacement
    1. Samsung 500C ChromeBook CPU Fan Replacement, CPU Fan: step 1, image 1 of 2 Samsung 500C ChromeBook CPU Fan Replacement, CPU Fan: step 1, image 2 of 2
      • Remove the seven screws from the back panel of the device using a Phillips #0 screwdriver.
      • Four of the screws are under the rubber feet so they will need to be removed with a spudger.
      • Remove the back panel from the laptop.
      Ask FixBot
    2. Samsung 500C ChromeBook CPU Fan Replacement: step 2, image 1 of 3 Samsung 500C ChromeBook CPU Fan Replacement: step 2, image 2 of 3 Samsung 500C ChromeBook CPU Fan Replacement: step 2, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the two screws holding in the CPU fan.
      • Lift the CPU fan.
      • You might encounter some slight resistance from the thermal paste on the heatsink.
      • Detach the cord attached to the fan and attach it to the new CPU fan.
      • Insert the new fan and reassemble the device.
      Ask FixBot
Enjoy your cool laptop!
2 other people completed this guide.
Garrett Kissinger
704 Reputation
5 Guides authored
1 Guide Comment
la pantalla no enciende, el ventilador arranca pero se apaga, el boton de poder da señal de encendido pero no enciende la pantalla
sergio rafael aguilar cantoral - Reply Share
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 107
All Time: 1,648
