Up to 20% off select tools
Samsung 351U Keyboard Key Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
91
All Time:
1,456
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Here we will walk you through replacing one of your keys.
    1. Samsung 351U Keyboard Key Replacement, Keyboard Key: step 1, image 1 of 1
      • Select the key you would like to remove then slide the plastic opening tool beneath it until you hear a pop.
      Ask FixBot
    2. Samsung 351U Keyboard Key Replacement: step 2, image 1 of 1
      • The key is now out and ready to be removed/replaced.
      • Be sure to only remove one key at a time so they will be in the same place as they were.
      • Clean the key and replace it into the same spot until another pop is heard.
      Ask FixBot
Author
with
Melvin Nelson
424 Reputation
3 Guides authored
USF Tampa, Team 12-4, Eyestone Spring 2017 Member of USF Tampa, Team 12-4, Eyestone Spring 2017
USFT-EYESTONE-S17S12G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 91
All Time: 1,456
