Tools
Introduction
Go to step 1 ↓The JOG button is used to control monitor functions like volume, brightness, and contrast. Common issues of this feature include the button sticking and the control stick breaking off.
Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
Tool used on this step:Heavy-Duty Spudger$4.99
Insert the heavy duty spudger in between the monitors back panel and its frame.
Use the heavy duty spudger to pry open the back panel.
