Up to 20% off select tools
Saeco XSmall disassembly
Views: 22K
View statistics:
Past 24 Hours:
13
Past 7 Days:
85
Past 30 Days:
312
All Time:
22,213
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
To repair internal components of the Saeco XSmall, the top cover must be removed. It is a large molded plastic piece which includes the top and the front. This guide will show you how to remove this.
      • Disconnect the power plug!
      • Remove pomace containers, water tank and brew unit
      Ask FixBot
    1. Saeco XSmall disassembly: step 2, image 1 of 2 Saeco XSmall disassembly: step 2, image 2 of 2
      • Remove the lid of the bean container and remove all coffee beans.
      • Remove the three Torx T10 screws securing the bean container.
      • The finger guard made of black plastic for the grinder is attached with a Phillips screw. Remove it to remove the finger guard.
      • Pull the bean container vertically up and remove it.
      Ask FixBot
    2. Saeco XSmall disassembly: step 3, image 1 of 2 Saeco XSmall disassembly: step 3, image 2 of 2
      • Take a photo of the grinder or note the position of the adjuster.
      • Pull the grinder adjuster upwards.
      Ask FixBot
    3. Saeco XSmall disassembly: step 4, image 1 of 1
      • Place the machine on its side. At the bottom of the top cover, to the left and right of the coffee spout, are two Torx T10 screws. Remove those.
      Ask FixBot
    4. Saeco XSmall disassembly: step 5, image 1 of 3 Saeco XSmall disassembly: step 5, image 2 of 3 Saeco XSmall disassembly: step 5, image 3 of 3
      • The cover over the coffee spout is held by detents. To release those insert a plastic opening tool. Start at the bottom, release the cover and set it aside.
      Ask FixBot
    5. Saeco XSmall disassembly: step 6, image 1 of 3 Saeco XSmall disassembly: step 6, image 2 of 3 Saeco XSmall disassembly: step 6, image 3 of 3
      • The top cover is now only held by detents. At the front side of bottom are two tabs that go into the bottom plate, which you have to consider when removing it.
      • Pay attention to the steam pipe.
      • Start at the back seam with opening. Gently pry with a plastic opening tool to split it.
      • When the detents are released, carefully lift the cover upwards with your hand and tilt it diagonally forward. Watch for the tabs that are in the bottom plate.
      • The steam pipe is still in the front cover. You must push the cover over the steam pipe when lifting it.
      Ask FixBot
    6. Saeco XSmall disassembly: step 7, image 1 of 2 Saeco XSmall disassembly: step 7, image 2 of 2
      • The coffeemaker is now open
      • The water heater
      • The coffee grinder
      Ask FixBot
13 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
VauWeh
349,359 Reputation
324 Guides authored
1 Guide Comment
Vielen Dank! Die Anleitung war uns gut geholfen.
wm1994 - Reply Share
Past 24 Hours: 13
Past 7 Days: 85
Past 30 Days: 312
All Time: 22,213
