Saeco SM Models: pump replacement
    1. Saeco SM Models: pump replacement, Housing: step 1, image 1 of 2 Saeco SM Models: pump replacement, Housing: step 1, image 2 of 2
      • Never forget: Unplug the machine!
      • Remove all attachments such as the water tank, brewing unit, bean compartment lid, and drip tray. Remove all coffee beans.
      • Turn the machine over so that the back is facing you. Remove the two Torx T10 screws at the bottom. Pull the back out slightly at the bottom and lift it down.
      • Important components are immediately visible:
      • The main circuit board
      • The pump
      • The flow meter
      • The boiler
      Ask FixBot
    2. Saeco SM Models: pump replacement: step 2, image 1 of 2 Saeco SM Models: pump replacement: step 2, image 2 of 2
      • Unscrew the Torx T10 screw on the finger guard in the coffee bean compartment.
      • Lift out the finger guard.
      • The screw is especially long.
      • Unscrew the three Torx T10 screws in the coffee bean compartment.
      Ask FixBot
    3. Saeco SM Models: pump replacement: step 3, image 1 of 3 Saeco SM Models: pump replacement: step 3, image 2 of 3 Saeco SM Models: pump replacement: step 3, image 3 of 3
      • Lift the upper cover slightly at the rear edge.
      • Then lift the cover completely off.
      • When reassembling, make sure that the grinder adjustment is correctly positioned.
      • Figure 3 shows the grinding mechanism, which can now easily be removed.
      Ask FixBot
    4. Saeco SM Models: pump replacement: step 4, image 1 of 3 Saeco SM Models: pump replacement: step 4, image 2 of 3 Saeco SM Models: pump replacement: step 4, image 3 of 3
      • Unscrew the two Torx T10 screws at the bottom of the front.
      • Slide the right side panel back slightly and remove it.
      • Slide the left side panel back slightly and remove it.
      Ask FixBot
    5. Saeco SM Models: pump replacement: step 5, image 1 of 2 Saeco SM Models: pump replacement: step 5, image 2 of 2
      • Other important components:
      • The boiler
      • Valve block, consisting of four solenoid valves
      • Grinder
      • Drive
      Ask FixBot
    1. Saeco SM Models: pump replacement, Pump: step 6, image 1 of 3 Saeco SM Models: pump replacement, Pump: step 6, image 2 of 3 Saeco SM Models: pump replacement, Pump: step 6, image 3 of 3
      • The pump is clearly visible in the back. It is installed in a vertical position and held by a rubber bracket.
      • To be on the safe side, remove the three black cables of the flowmeter from their holder so that the pump has a free path.
      • Pull the two flat connectors off the pump.
      • The thermal fuse on the cable is glued to the pump at the factory. Carefully scrape off the adhesive and pull the thermal fuse out downwards.
      • When reassembling, attach the thermal fuse to the new pump with a piece of electrical tape.
      Ask FixBot
    2. Saeco SM Models: pump replacement: step 7, image 1 of 3 Saeco SM Models: pump replacement: step 7, image 2 of 3 Saeco SM Models: pump replacement: step 7, image 3 of 3
      • The rubber holder for the pump is hooked at the top. Push the rubber hook away from you with a metal spatula and leave the metal spatula in place.
      • Take a strong screwdriver and now push the bracket with a lot of force towards the water tank side until it gradually comes out together with the pump.
      • Lift out the pump. It is still connected with two hoses.
      Ask FixBot
    3. Saeco SM Models: pump replacement: step 8, image 1 of 1
      • Pull the pump out of the lower water connection.
      • Insert a 12 mm open-end wrench into the upper pump outlet.
      • Turn the black connection slightly counterclockwise until it comes loose.
      • Turn the pump all the way out.
      • Take care of the seal on the upper connection. Replace it if necessary when replacing the pump.
      Ask FixBot
    4. Saeco SM Models: pump replacement: step 9, image 1 of 3 Saeco SM Models: pump replacement: step 9, image 2 of 3 Saeco SM Models: pump replacement: step 9, image 3 of 3
      • The factory-installed pump was an Ulka EP5FMGW. Replace it with an Ulka EX5, which has a metal fitting.
      • Ulka pumps can be opened and possibly repaired, but replacement is usually better.
      • Secure the thermal fuse to the pump with electrical tape.
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
VauWeh is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
342,143 Reputation
315 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
40 Members
7,000 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 74
Past 30 Days: 214
All Time: 2,857
