Saeco Royal brewing unit disassembly
  1. Saeco Royal brewing unit disassembly, Cream valve and spout: step 1, image 1 of 3 Saeco Royal brewing unit disassembly, Cream valve and spout: step 1, image 2 of 3 Saeco Royal brewing unit disassembly, Cream valve and spout: step 1, image 3 of 3
    • These parts differ in details depending on the model
    • Two screws hold the part, loosen. A seal becomes free, pick up well, better still replace later.
    • Inside is a feather and a small glass ball. Store carefully.
    Ask FixBot
  2. Saeco Royal brewing unit disassembly, The brewing sieve: step 2, image 1 of 2 Saeco Royal brewing unit disassembly, The brewing sieve: step 2, image 2 of 2
    • With a 6mm Allen key (or the key that comes with the machine), the brewing sieve can be unscrewed. It strongly determines the aroma, if it is dirty the coffee tastes bad.
    Ask FixBot
  3. Saeco Royal brewing unit disassembly, The upper piston: step 3, image 1 of 3 Saeco Royal brewing unit disassembly, The upper piston: step 3, image 2 of 3 Saeco Royal brewing unit disassembly, The upper piston: step 3, image 3 of 3
    • He is held in place by four latches. These impress, e.g. with a screwdriver, then the piston can be pushed down.
    • The new sealing ring is already waiting, but first it has to be cleaned properly.
    Ask FixBot
  4. Saeco Royal brewing unit disassembly, Intake: step 4, image 1 of 3 Saeco Royal brewing unit disassembly, Intake: step 4, image 2 of 3 Saeco Royal brewing unit disassembly, Intake: step 4, image 3 of 3
    • Through the hole on the opposite side of the fixing screw can be solved. The inlet is plugged in and held by a latch, which you have to push away.
    Ask FixBot
  5. Saeco Royal brewing unit disassembly, dismantle: step 5, image 1 of 3 Saeco Royal brewing unit disassembly, dismantle: step 5, image 2 of 3 Saeco Royal brewing unit disassembly, dismantle: step 5, image 3 of 3
    • Three screws hold the brew groups together, loosen.
    • The whole mechanics can now be broken down into three big parts. The coffee funnel can stay.
    Ask FixBot
  6. Saeco Royal brewing unit disassembly, Umlenkhebel: step 6, image 1 of 2 Saeco Royal brewing unit disassembly, Umlenkhebel: step 6, image 2 of 2
    • That's the trickiest part: you have to lever this lever out of its camp. To do this you drive with a screwdriver between the lever and the carrier and press it really very strong outwards. Now he grabs out - hopefully!
    Ask FixBot
  7. Saeco Royal brewing unit disassembly, Lower piston: step 7, image 1 of 1
    • Since the lever is gone you can easily pull out the piston. It has no seal.
    • The lower piston itself has no gasket. But the shaft of the piston slides in an o-ring. which is situated under the brewing chamber. It can be changed, but it´s not easy to do this.
    Ask FixBot
  8. Saeco Royal brewing unit disassembly, Clean: step 8, image 1 of 1
    • That's why we did it. All parts are thoroughly cleaned. For this purpose, a solution of machine detergent is good. (Use rubber gloves!) Clean all channels with pipe cleaners. The brewing sieve is like new again! Allow to dry well.
    • Then apply new gaskets, in particular to the crema valve and piston and lubricate with food-grade grease.
    • Fat also belongs to the bearings of the rocker arm and into the slides, the piston skirt, as well as into the water inlet
    Ask FixBot
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
335,795 Reputation
311 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 82
All Time: 6,659
