Saeco Royal Pump Replacement
Views: 4.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
89
All Time:
4,849
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
If the pump no longer works properly, remove it and overhaul or replace it. These instructions will show you how to do this. You will have to open the machine. It is recommended to remove the thermoblock. The pictures are from a Saeco Royal Sup 014, but the repair is similar for machines of the series Royal - Magic - Stratos.
Note: in this manual, the thermoblock has been completely removed. The effort is not very big and the pump is easier to remove. You can also skip the steps that involve removing the thermoblock.
These instructions may also help with other Saeco models and with coffee makers from Philips and Gaggia—they are all made by the same manufacturer and have a very similar design.
Tools
    1. Saeco Royal Pump Replacement, Preparing: step 1, image 1 of 1
      • Unplug!
      • Remove all attachments like water tank, brewing unit etc.
      • The pictures show a Royal Cappucino One Touch HD8930, but the opening procedure is similar to all models.
      Ask FixBot
    2. Saeco Royal Pump Replacement, Top: step 2, image 1 of 2 Saeco Royal Pump Replacement, Top: step 2, image 2 of 2
      • The coffeebean supply is fixed with two screws. Unscrew them and lift it off.
      • There is a black rubber lid under the bean hopper that you can easily lift off, leaving a large opening.
      • The adjuster of the grinder has to be solved. Mark the position or just take a picture. This type is fixed with a screw, others are only sticked together.
      Ask FixBot
    3. Saeco Royal Pump Replacement, Rear side: step 3, image 1 of 1
      • There are two screws to be turned out.
      Ask FixBot
    4. Saeco Royal Pump Replacement, Front: step 4, image 1 of 3 Saeco Royal Pump Replacement, Front: step 4, image 2 of 3 Saeco Royal Pump Replacement, Front: step 4, image 3 of 3
      • The screws are situated on the underneath of the cover. This type is held by four screws.
      Ask FixBot
    5. Saeco Royal Pump Replacement, Lift cover off: step 5, image 1 of 2 Saeco Royal Pump Replacement, Lift cover off: step 5, image 2 of 2
      • Now the cover can be raised: first grip on left and right rear side and lift about 10 cm (4 in). Sometimes the cover jams a little bit.
      • Solve the hoses which lead to the water tank. Perhaps you have to pull out some contacts, (e.g. the yellow-green protection lead), don´t forget to put them on again later.
      • The cover can be drawn aslant towards the front, sliding it over the hot water pipe.
      • Most repairs can be done with the cover being laid up partially , it must not be completely removed.
      Ask FixBot
    1. Saeco Royal Pump Replacement, Pump replacement: step 6, image 1 of 2 Saeco Royal Pump Replacement, Pump replacement: step 6, image 2 of 2
      • Here the pump viewed from above, a Ulka EX5 with 230V. The pump is stored in rubber pieces.
      • Pull the silicone hose off the rear elbow.
      • If not already done, remove the clamp on the pressure hose on the pressure relief valve. Then remove the pressure hose.
      • The pressure hose is sealed with two O-rings at the end. These will usually hang at the end. Replace them before re-assembling.
      Ask FixBot
    2. Saeco Royal Pump Replacement: step 7, image 1 of 3 Saeco Royal Pump Replacement: step 7, image 2 of 3 Saeco Royal Pump Replacement: step 7, image 3 of 3
      • In the first picture, the pump has already been removed. The red marking shows the catch that holds the rubber molded part. You can easily pull it out when the catch is pressed down.
      • Pull the angled molded rubber parts out of their spots on the floor.
      • Lift the pump with the rubber moldings out of the machine.
      • When reassembling, make sure that the molded rubber part is correctly attached.
      Ask FixBot
    1. Saeco Royal Pump Replacement, Replacing the pump: step 8, image 1 of 1
      • Unscrew the pressure relief valve with two wrenches SW 10 and 13.
      • Only the pump itself as well as the relief valve will remain.
      • If you want to replace the pump, you'll have to transfer the pressure relief valve to the new pump. You should also service your valve while you're at it.
      Ask FixBot
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
344,819 Reputation
317 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 89
All Time: 4,849
