Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Saeco PicoBaristo Test Mode
View statistics:
Past 24 Hours:
18
Past 7 Days:
21
Past 30 Days:
21
All Time:
21
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Very easy
Introduction
Go to step 1 ↓
The PicoBaristo is very easy to put into test mode. Then you can easily check many functions.
This guide can also help with other Saeco models and with fully automatic coffee machines from Philips and Gaggia – the devices all come from the same manufacturer and have a very similar design.
    1. Saeco PicoBaristo Test Mode, Enter test mode: step 1, image 1 of 3 Saeco PicoBaristo Test Mode, Enter test mode: step 1, image 2 of 3 Saeco PicoBaristo Test Mode, Enter test mode: step 1, image 3 of 3
      • The device is initially in standby mode.
      • To enter test mode, press the top-left and bottom-right buttons simultaneously. Then, press the power button.
      • The firmware version message will appear on the display.
      • Press the power button each time to move to the next screen.
      Ask FixBot
    2. Saeco PicoBaristo Test Mode, Testing the buttons: step 2, image 1 of 2 Saeco PicoBaristo Test Mode, Testing the buttons: step 2, image 2 of 2
      • The next screen allows you to test the buttons. When you press one of the buttons, the screen turns red and a "Y" appears behind the button number if it is working.
      • When you press button 12 - Power button, the next screen will naturally appear.
      • In the image, button 1 - Espresso - is being pressed.
      Ask FixBot
    3. Saeco PicoBaristo Test Mode, Sensors: step 3, image 1 of 1
      • The next screen shows whether sensors are triggered:
      • water tank
      • Milk carafe
      • Water missing
      • Beans missing
      • Service door open
      • Brew unit in park position
      Ask FixBot
    4. Saeco PicoBaristo Test Mode, Brew unit motor: step 4, image 1 of 1
      • You can move the brew unit up or down using the two illuminated buttons ^ and v.
      • Work indicates the upper end position.
      • Home indicates the lower end position.
      Ask FixBot
    5. Saeco PicoBaristo Test Mode, Solenoid valve and pump: step 5, image 1 of 1
      • The illuminated button on the left controls the EV1 solenoid valve.
      • If it does not click audibly, it is no longer working properly.
      • The illuminated button on the right controls the pump.
      • The pump must be clearly audible. The display shows the flow meter pulses and the flow rate in liters/h.
      Ask FixBot
    6. Saeco PicoBaristo Test Mode, Heating and grinder: step 6, image 1 of 1
      • The illuminated button on the left controls the heating.
      • The temperature is displayed in °C. It must increase when the heating is set to ON.
      • The illuminated button on the right controls the grinder.
      • The RPM of the grinder is shown on the display.
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
VauWeh
349,359 Reputation
324 Guides authored
0 Guide Comments
Past 24 Hours: 18
Past 7 Days: 21
Past 30 Days: 21
All Time: 21
