This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Saeco Moltio Grinder Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
37
Past 30 Days:
124
All Time:
915
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide shows the removal of the grinder in a Saeco Moltio. The ceramic grinder is the same on newer models from Saeco - Philips - Gaggia. If only the grinding burrs are dull, you can replace them. If only the motor is defective, you can replace it. If the grinder is completely defective, you can replace the entire unit.
    1. Saeco Moltio Grinder Replacement, Metal or plastic trim frame?: step 1, image 1 of 2 Saeco Moltio Grinder Replacement, Metal or plastic trim frame?: step 1, image 2 of 2
      • First, check which model you have: is the trim frame made of chrome-plated metal (image 1) or metallized plastic (image 2)? In the first case, use this guide; in the second case, use this guide. Then return here.
      Ask FixBot
    2. Saeco Moltio Grinder Replacement, Grinder information: step 2, image 1 of 1
      • The grinder is easily accessible from the top. It sits loosely, but is connected with two cables and one cable to the sensor.
      • Do not change any settings.
      Ask FixBot
    3. Saeco Moltio Grinder Replacement, Disconnecting the connectors: step 3, image 1 of 2 Saeco Moltio Grinder Replacement, Disconnecting the connectors: step 3, image 2 of 2
      • Carefully lift the grinder and pull off the two spade connectors from the motor. You must press in a small locking tab on each connector to do this.
      • Be sure to note which cable is connected where, so that the motor does not run in reverse later.
      • Once you have lifted the grinder, you will also see the cable for the sensor on the underside. Trace the cable to the main board. Very carefully disconnect the connector.
      Ask FixBot
    4. Saeco Moltio Grinder Replacement, Lift out the grinder: step 4, image 1 of 1
      • Lift the grinder straight up and out. Feed the cables through the opening in the housing.
      • The seal on the coffee grounds chute is only inserted. Be careful not to lose it.
      • The damping spring is only inserted. Be careful not to lose it.
      • When reassembling, make sure that the holes in the rubber mount around the motor are properly seated on the corresponding pins.
      Ask FixBot
Follow these steps in reverse order to reassemble your device.
VauWeh
344,427 Reputation
317 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
43 Members
7,058 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 37
Past 30 Days: 124
All Time: 915
