Up to 20% off select tools
Saeco Exprelia function valve replacement
Views: 16K
View statistics:
Past 24 Hours:
5
Past 7 Days:
35
Past 30 Days:
233
All Time:
15,831
Comments: 12
10 comments on steps, 2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
The function valve is located on the left side of the device on the water tank. There may be a leak, then water will drip out on the left side in the middle of the machine. The replacement is quite easy.
These instructions may also help with other Saeco models and with coffee makers from Philips and Gaggia—they are all made by the same manufacturer and have a very similar design.
    1. Saeco Exprelia function valve replacement, remove back cover: step 1, image 1 of 1
      • Remove all accessory parts like the water reservoir, the brewing assembly as well as the drip try.
      • Remove all coffee beans from the bean container
      • Always remove the power cord
      • Remove the two T10 Torx screws from the bottom of the rear cover.
      Ask FixBot
    2. Saeco Exprelia function valve replacement: step 2, image 1 of 1
      • Pull the back cover approximately 1 cm (3/8inch) out from the bottom and push it in an upward direction.
      Ask FixBot
    1. Saeco Exprelia function valve replacement, rear frame: step 3, image 1 of 2 Saeco Exprelia function valve replacement, rear frame: step 3, image 2 of 2
      • Remove the five T10 Torx screws as marked
      • the back frame consist of 3 pieces. Lift the top part out first, then each one of the side pieces
      Ask FixBot
    1. Saeco Exprelia function valve replacement, top cover: step 4, image 1 of 3 Saeco Exprelia function valve replacement, top cover: step 4, image 2 of 3 Saeco Exprelia function valve replacement, top cover: step 4, image 3 of 3
      • Lift the bean compartment lid and loosen the Torx T10 screw.
      • Open the water compartment lid and loosen the Torx T10 screw.
      • The lid is locked into place several times. Carefully loosen the catches and lift off the lid.
      • Note: If you only want to remove the left cover on the water compartment, all you need to do is loosen the cover a little and lift it up by about 2 cm.
      Ask FixBot
    1. Saeco Exprelia function valve replacement, left panel: step 5, image 1 of 1
      • Open the front access door.
      • Lift the top cover by about 2 cm until you can just reach the screw in the top right.
      • Remove the T10 Torx screw
      Ask FixBot
    2. Saeco Exprelia function valve replacement: step 6, image 1 of 1
      • Lift the top cover slightly upwards. It requires a fair amount of force to push the side cover upwards by about 5 mm until the hooks are released and then lift it out.
      Ask FixBot
    1. Saeco Exprelia function valve replacement, Check function valve: step 7, image 1 of 1
      • The function valve is easy to see on the left. If it shows signs of limescale on the outside, it is probably leaking. First check whether it is only the top connection does not seal well.
      • Pull out the metal clip on the top connector.
      • Now carefully lift out the upper connection piece. Check the O-ring, replace it if possible.
      • The hose is attached with an Oetiker clamp. It must be destroyed to be removed. Replace it later with a suitable hose clip. Shorten the tube about 1 cm.
      • Reassemble the valve and check that it is now tight. (Caution, the cables are exposed). If it is not then it will have to be repalced.
      Ask FixBot
    2. Saeco Exprelia function valve replacement, Replacement of the valve: step 8, image 1 of 1
      • Rotate the machine so it is facing you with the door open.
      • Remove the Phillips screw in the center left. Now you can reach the fastening screw on the function valve.
      Ask FixBot
    3. Saeco Exprelia function valve replacement: step 9, image 1 of 2 Saeco Exprelia function valve replacement: step 9, image 2 of 2
      • Insert a T10 Torx screwdriver through the screw hole you just opened and unscrew the fastening screw on the function valve.
      • You can avoid opening the outer clamp by pulling the clamps on the connecting piece - as shown here - and replacing the connecting piece on the new part.
      • Pull off the metal clip for the rear connection and carefully remove the valve.
      • Pull off the two flat plugs.
      • Loosen all hose connections, including those on the back.
      • The valve is now free to be removed
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
4 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
VauWeh
349,015 Reputation
323 Guides authored
2 Guide Comments
Hi,
Gibt es auch eine Anleitung für den Körper des Funktionsventil also das Hintere schwarze Teil?
Danke
Chris - Reply Share
.. .also wie man es zerlegt? Habe ich schon probiert, ist nicht sehr schwer. Hat aber nichts gebracht und ich habe es austauschen müssen.
VauWeh - Reply Share
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 233
All Time: 15,831
