SYNOLOGY DS218 +: a complete disassembly in rules
    1. SYNOLOGY DS218 +: a complete disassembly in rules, Presentation: the different faces of the case: step 1, image 1 of 3 SYNOLOGY DS218 +: a complete disassembly in rules, Presentation: the different faces of the case: step 1, image 2 of 3 SYNOLOGY DS218 +: a complete disassembly in rules, Presentation: the different faces of the case: step 1, image 3 of 3
      • Here are the different interesting faces of the case: front (bay disks), rear (connectors and fan).
      • This NAS DS218 + is equiped with 2 GB of RAM (6 GB max.), An INTEL Celeron J3355 64-bit Dual core processor, two bays for SATA drives.
      • 1 x RJ45 Gb port.
      • Kensington security incision (K-lock)
      • 1 x port for power supply
      • 3 x USB 3 ports (1 in front and 2 behind)
      • 1 x eSATA port
      Ask FixBot
    2. SYNOLOGY DS218 +: a complete disassembly in rules, Teardown : remove disk media: step 2, image 1 of 3 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown : remove disk media: step 2, image 2 of 3 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown : remove disk media: step 2, image 3 of 3
      • nothing very hard … remove the disk media by pressing "push" buton.
      Ask FixBot
    3. SYNOLOGY DS218 +: a complete disassembly in rules, Backplane and memory slot access: step 3, image 1 of 2 SYNOLOGY DS218 +: a complete disassembly in rules, Backplane and memory slot access: step 3, image 2 of 2
      • 2 x SATA port
      • Only the empty memory slot is reachable.
      • The one used (memory slot) is not reachable. The case must be unmounted integraly to access to this memory slot (see step 13).
      Ask FixBot
    4. SYNOLOGY DS218 +: a complete disassembly in rules, Case: removing the cover 1/2: step 4, image 1 of 2 SYNOLOGY DS218 +: a complete disassembly in rules, Case: removing the cover 1/2: step 4, image 2 of 2
      • Remove the screw on the back of the case next to Kensington incision.
      • Fan screws removal is not needed …
      Ask FixBot
    5. SYNOLOGY DS218 +: a complete disassembly in rules, Housing: cover removal 2/2: step 5, image 1 of 3 SYNOLOGY DS218 +: a complete disassembly in rules, Housing: cover removal 2/2: step 5, image 2 of 3 SYNOLOGY DS218 +: a complete disassembly in rules, Housing: cover removal 2/2: step 5, image 3 of 3
      • Once rear screws removed …
      • there are two lock lugs (front panel left side) to unlock.
      • Use a flat screwdriver to pry. Be careful not to twist the metal bar.
      • Then slide the NAS in the direction of the length as in the photos.
      Ask FixBot
    6. SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: internal parts: step 6, image 1 of 3 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: internal parts: step 6, image 2 of 3 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: internal parts: step 6, image 3 of 3
      • in orange: internal SATA ports
      • in yellow: fan connector
      • in blu: fan
      • in green: free (empty) memory slot
      Ask FixBot
    7. SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: spacer holding cage and case: step 7, image 1 of 3 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: spacer holding cage and case: step 7, image 2 of 3 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: spacer holding cage and case: step 7, image 3 of 3
      • simply unscrew the screw to remove the spacer.
      • you will notice the guides (keying) to position the spacer.
      Ask FixBot
    8. SYNOLOGY DS218 +: a complete disassembly in rules, Disassembly: spacer holding fan: step 8, image 1 of 2 SYNOLOGY DS218 +: a complete disassembly in rules, Disassembly: spacer holding fan: step 8, image 2 of 2
      • same as before ... unscrew the screw to remove the plastic spacer
      • you will also notice the keysters ...
      Ask FixBot
    9. SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: removal of the fan: step 9, image 1 of 2 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: removal of the fan: step 9, image 2 of 2
      • the fan has been removed for the tutorial. This is not mandatory ... but better to have a little more room!
      • Only the connector must be removed for disassembly
      • beware of the tape to take off before!
      Ask FixBot
    10. SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: removal of the motherboard 1/2: step 10, image 1 of 3 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: removal of the motherboard 1/2: step 10, image 2 of 3 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: removal of the motherboard 1/2: step 10, image 3 of 3
      • to remove the motherboard from the box, unscrew the 4 screws as below ...
      Ask FixBot
    11. SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: removal of the motherboard 2/2: step 11, image 1 of 3 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: removal of the motherboard 2/2: step 11, image 2 of 3 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: removal of the motherboard 2/2: step 11, image 3 of 3
      • once the screws are removed, pull the front slightly outwards ...
      • This allows the front panel connectors to pass through.
      • … then lift up the motherboard by holding the disk cage.
      Ask FixBot
    12. SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: removal of the disk bay: step 12, image 1 of 2 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: removal of the disk bay: step 12, image 2 of 2
      • remove the screws marked in yellow (x4)
      • no specific photographs ... nothing very complex!
      Ask FixBot
    13. SYNOLOGY DS218 +: a complete disassembly in rules, Internal parts: case, motherboard: step 13, image 1 of 3 SYNOLOGY DS218 +: a complete disassembly in rules, Internal parts: case, motherboard: step 13, image 2 of 3 SYNOLOGY DS218 +: a complete disassembly in rules, Internal parts: case, motherboard: step 13, image 3 of 3
      • 1 - motherboard (processor side)
      • 2 - motherboard (memory side)
      • 3 - empty case
      Ask FixBot
    14. SYNOLOGY DS218 +: a complete disassembly in rules, Many thanks!: step 14, image 1 of 1
      • photograph showing one of the phases of the NAS teardown.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
27 other people completed this guide.
Special thanks to these translators:
fr en
100%
Sébastien is helping us fix the world! Want to contribute?
Start translating ›
Sébastien
4,739 Reputation
6 Guides authored
AEM (ANIMA EX MACHINA) Member of AEM (ANIMA EX MACHINA)
Business
1 Member
72 Guides authored
10 Guide Comments
Merci, c’est super sympa. Au top tes photos. Ca m’a permis de voir qu’il n’y a pas de ventilateur sur la carte mère.
Je viens d’en acheter un et j’hésite à changer le ventilateur car il est trop bruyant à mon goût, j’ai deux ssd dedans, donc pas de risque de ventilation trop faible. A voir la compatibilité des ventilos maintenant.
Avec ton tuto, je serai bien guidé pour le démontage !
Tanguy Westelynck - Reply Share
super tuto qui me serra très utile car je dois changer mon ventilateur ! Merci !
Francesco DE PALMA - Reply Share
Muchas gracias. Es igualmente valido para el modelo DS220+. El motivo fue acceder a la pila de la BIOS que había quedado suelta, se encuentra en la parte inferior de la placa, junto a los conectores traseros.
En el paso 4, si recomendaría retirar los tornillos del ventilador.
Amado Gonzalez-Bedoya - Reply Share
Many thanks for this article. It is very helpful. Would anybody have a photo of the motherboard (processor side) in a higher resolution?
One IC on my NAS burnt and I am unable to read its value so I can replace it.
Many thanks
Rick - Reply Share
Hi Rick,
It's like me ? https://we.tl/t-6yCq1mSDH7
[deleted] - Reply Share
Past 24 Hours: 14
Past 7 Days: 94
Past 30 Days: 376
All Time: 38,156
