Up to 20% off select tools
SVP 5800 Back Casing Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
80
All Time:
1,157
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
How to replace the back casing to SVP Aqua 5800
    1. SVP 5800 Back Casing Replacement, Strap Hook: step 1, image 1 of 3 SVP 5800 Back Casing Replacement, Strap Hook: step 1, image 2 of 3 SVP 5800 Back Casing Replacement, Strap Hook: step 1, image 3 of 3
      • Locate the two 3.5 mm screws on the side of the device.
      • Apply pressure to the PH J000 philips head screwdriver and turn in a counter clockwise motion until the screw becomes loose enough to pull out.
      Ask FixBot
    1. SVP 5800 Back Casing Replacement, Front Casing: step 2, image 1 of 2 SVP 5800 Back Casing Replacement, Front Casing: step 2, image 2 of 2
      • Once you have properly removed the strap hook, locate the two 3 mm screws located on the opposite side of the strap hook.
      • Refer to the prerequisite guide on removing the strap hook for instructions.
      • Place the PH J000 phillips head screwdriver on the head of screw; apply pressure and turn in a counter clockwise motion until screws come loose.
      Ask FixBot
    2. SVP 5800 Back Casing Replacement: step 3, image 1 of 2 SVP 5800 Back Casing Replacement: step 3, image 2 of 2
      • Place the plastic opening tool on the crack between the front and back casings.
      • Apply pressure by pulling down on the plastic opening tool to pry the case apart.
      Ask FixBot
    3. SVP 5800 Back Casing Replacement: step 4, image 1 of 2 SVP 5800 Back Casing Replacement: step 4, image 2 of 2
      • Wedge your fingers in the opening and slowly pull the front casing away from the bottom casing until it complete separates from the device.
      • Using too much force in this step can damage your device.
      Ask FixBot
    1. SVP 5800 Back Casing Replacement, Top button Compartment: step 5, image 1 of 3 SVP 5800 Back Casing Replacement, Top button Compartment: step 5, image 2 of 3 SVP 5800 Back Casing Replacement, Top button Compartment: step 5, image 3 of 3
      • Insert the flat end of wide metal spudger into the seam of the plastic buffer surrounding the buttons and pry it open.
      Ask FixBot
    2. SVP 5800 Back Casing Replacement: step 6, image 1 of 3 SVP 5800 Back Casing Replacement: step 6, image 2 of 3 SVP 5800 Back Casing Replacement: step 6, image 3 of 3
      • Use A #00 Phillips head screwdriver and turn counterclockwise to remove the four indicated screws.
      • Set the screws aside.
      Ask FixBot
    3. SVP 5800 Back Casing Replacement: step 7, image 1 of 2 SVP 5800 Back Casing Replacement: step 7, image 2 of 2
      • Apply pressure and turn counterclockwise to remove the indicated 2.5 mm screw.
      Ask FixBot
    1. SVP 5800 Back Casing Replacement, Back Casing: step 8, image 1 of 2 SVP 5800 Back Casing Replacement, Back Casing: step 8, image 2 of 2
      • Locate the 2 mm screw that is next to the battery compartment.
      • Using the PH J000 phillips head screwdriver, apply pressure to the screw head and turn in a counter clockwise motion until the screw is loose.
      • You do not have to completely remove the 2 mm screw. To prevent losing the screw, you may leave it loosely in its place.
      Ask FixBot
    2. SVP 5800 Back Casing Replacement: step 9, image 1 of 3 SVP 5800 Back Casing Replacement: step 9, image 2 of 3 SVP 5800 Back Casing Replacement: step 9, image 3 of 3
      • Slide the flat edge of the plastic opening tool between the inner casing and the back outer casing.
      • Push up on the plastic opening tool so that the back casing starts to lift from the inner casing.
      • Lifting the casing too far may result in damage. Lift the casing slowly.
      Ask FixBot
Author
with
Cheyenne Heinen
358 Reputation
3 Guides authored
Marist, Team 1-3, Laflen Spring 2016 Member of Marist, Team 1-3, Laflen Spring 2016
MARS-LAFLEN-S16S1G3
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 80
All Time: 1,157
