This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓The air filter in your STIHL MS 201 T chainsaw is essential for protecting the engine from dust and debris, ensuring optimal performance. Over time, this filter can become clogged or worn, reducing your machine's efficiency. This guide will show you how to replace the air filter on your chainsaw in a few simple steps, to ensure reliable operation and extend the life of your equipment.
Make sure the chainsaw is turned off and the engine is completely cooled down.
Now that you have removed your STIHL MS201T air filter, you can replace it by following the steps in reverse order.
If your filter is dirty but not damaged, you can clean it. First, use compressed air (compressor) to remove the dirt. Next, clean it with soapy water or STIHL Varioclean Eco cleaner. Let it sit for 15 to 20 minutes, then rinse it with clean water and let it dry completely in the sun.
To reassemble your device, follow the instructions in reverse order.
