This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓If your air filter is damaged or worn, it is necessary to replace it to ensure the proper operation and longevity of your chainsaw. An air filter in good condition prevents debris and dust from entering the engine, which could cause damage or reduce performance. Follow this guide to learn how to remove and replace the STIHL MS150 TC chainsaw air filter, along with tips on how to clean it if possible.
Now that you have removed your STIHL Ms150TC air filter, you can replace it by following the steps in reverse order.
If your filter is dirty but not damaged, you can clean it. First, use compressed air to remove the dirt. Then, clean it with soapy water or STIHL Varioclean Eco cleaner. Let it sit for 15 to 20 minutes, then rinse it with clean water and let it dry completely in the sun.
To reassemble your device, follow the instructions in reverse order.
