This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
SSD Replacement
    1. SSD Replacement, removal of bottom case: step 1, image 1 of 2 SSD Replacement, removal of bottom case: step 1, image 2 of 2
      • remove the feet with a spudger
      Ask FixBot
    2. SSD Replacement: step 2, image 1 of 2 SSD Replacement: step 2, image 2 of 2
      • Remove the 11 screw with a PH0 screwdriver.
      • The screws are identical
      Ask FixBot
    3. SSD Replacement: step 3, image 1 of 2 SSD Replacement: step 3, image 2 of 2
      • Insert a spudger between the bottom cover and the keyboard module, then go around the whole cover to uncip everything.
      • Remove the bottom cover from the computer.
      Ask FixBot
    4. SSD Replacement: step 4, image 1 of 1
      • You now have acces to the inside of the machine.
      Ask FixBot
    1. SSD Replacement, SSD: step 5, image 1 of 1
      • remove the screw with your PH0 screwdriver
      Ask FixBot
    2. SSD Replacement: step 6, image 1 of 2 SSD Replacement: step 6, image 2 of 2
      • slide the SSD out of the m.2 slot
      • It may be necessary to slightly lift up the back of the SSD
      • The SSD is now removed
      Ask FixBot
Install your SSD
To reassemble your machine, follow the instructions in reverse order.
Special thanks to these translators:
fr en
40%
S Devaud is helping us fix the world! Want to contribute?
Start translating ›
Léo FRAYSSE
1,455 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 30
All Time: 869
