SRS-XB22 Battery Replacement
    1. SRS-XB22 Battery Replacement, Remove the front grill: step 1, image 1 of 3 SRS-XB22 Battery Replacement, Remove the front grill: step 1, image 2 of 3 SRS-XB22 Battery Replacement, Remove the front grill: step 1, image 3 of 3
      • Firstly, you need to pry the speaker grill away from the speaker.
      • Use a spudger/guitar pick to prise up each end of the grill.
      • You are trying to lift a clip at either end. (circled in red)
      • Once lifted at both ends, gently pull the grill forwards.
      Ask FixBot
    2. SRS-XB22 Battery Replacement, Unscrew the speakers: step 2, image 1 of 3 SRS-XB22 Battery Replacement, Unscrew the speakers: step 2, image 2 of 3 SRS-XB22 Battery Replacement, Unscrew the speakers: step 2, image 3 of 3
      • Completely remove the grill.
      • Remove the 8 screws that hold the speakers in place.
      • Slowly pull the speakers forward to free them from the case.
      Ask FixBot
    3. SRS-XB22 Battery Replacement, Remove the speakers: step 3, image 1 of 3 SRS-XB22 Battery Replacement, Remove the speakers: step 3, image 2 of 3 SRS-XB22 Battery Replacement, Remove the speakers: step 3, image 3 of 3
      • Disconnect the speaker cables from the internal circuit boards.
      • Be careful, the sockets are easy to damage
      • Remove both of the rubber gaskets from the case - one for the left speaker, one for the right.
      Ask FixBot
    4. SRS-XB22 Battery Replacement, Removing the outer case.: step 4, image 1 of 3 SRS-XB22 Battery Replacement, Removing the outer case.: step 4, image 2 of 3 SRS-XB22 Battery Replacement, Removing the outer case.: step 4, image 3 of 3
      • Starting at the ends of the speaker, prise the back case away from the main unit.
      • Work your way along the front of the case.
      • Once the front in freed, work you way along the edges, freeing the whole case.
      • There is A LOT of double sided tape between the outer and inner case. It requires a lot of work to remove it.
      • The case is one piece. Although it looks as if it splits at the rear, it is sealed together.
      Ask FixBot
    5. SRS-XB22 Battery Replacement, Remove the rear casing: step 5, image 1 of 2 SRS-XB22 Battery Replacement, Remove the rear casing: step 5, image 2 of 2
      • Remove the rear outer casing of the speaker.
      Ask FixBot
    6. SRS-XB22 Battery Replacement, Remove the front cover: step 6, image 1 of 3 SRS-XB22 Battery Replacement, Remove the front cover: step 6, image 2 of 3 SRS-XB22 Battery Replacement, Remove the front cover: step 6, image 3 of 3
      • Remove 3 screws at either end of the speaker, so 6 screws in total.
      • Using a spudger, unclip the top and bottom plastic clips, holding the front of the speaker.
      • (I made the error and removed the illuminated surround, hence it is not in two of my pictures here - it is NOT necessary to remove it)
      Ask FixBot
    7. SRS-XB22 Battery Replacement, Disconnect the front panel: step 7, image 1 of 2 SRS-XB22 Battery Replacement, Disconnect the front panel: step 7, image 2 of 2
      • Slowly pull the front panel forwards.
      • Be careful, there are 3 wires still connected.
      • Disconnect the three wires, freeing the front panel.
      Ask FixBot
    8. SRS-XB22 Battery Replacement, Freeing the internal components: step 8, image 1 of 3 SRS-XB22 Battery Replacement, Freeing the internal components: step 8, image 2 of 3 SRS-XB22 Battery Replacement, Freeing the internal components: step 8, image 3 of 3
      • Lift the rubber gasket away from the unit.
      • Locate the 6 screws holding the internal structure in place.
      • Remove these 6 screws.
      Ask FixBot
    9. SRS-XB22 Battery Replacement: step 9, image 1 of 3 SRS-XB22 Battery Replacement: step 9, image 2 of 3 SRS-XB22 Battery Replacement: step 9, image 3 of 3
      • Use a spudger to lift the button away from the speaker.
      • Be careful, it's held down by more sticky tape!
      Ask FixBot
    10. SRS-XB22 Battery Replacement, Remove the internal structure: step 10, image 1 of 1
      • Slide the main plastic unit forward from the speaker.
      • There will still be a couple of circuit boards in the back that are connected. These are the boards for the rear panel.
      Ask FixBot
    11. SRS-XB22 Battery Replacement, Remove the battery: step 11, image 1 of 3 SRS-XB22 Battery Replacement, Remove the battery: step 11, image 2 of 3 SRS-XB22 Battery Replacement, Remove the battery: step 11, image 3 of 3
      • Disconnect the battery lead from the circuit board.
      • Carefully, pull the battery out of its recess.
      Ask FixBot
13 other people completed this guide.
Charlie Turner
613 Reputation
1 Guide authored
6 Guide Comments
has anyone ever heard the battery lady come on by herself? could it be cause I knocked it a bit too hard accidentally while attached to backpack? I loosened something inside on board?
Jeff Sparky - Reply Share
So the battery type is st-05s, thank you.
Karlis Liepa - Reply Share
Battery order plz
Somi Rai - Reply Share
you can find it on amazon. this is the one im trying out tomorrow.
https://www.amazon.com/gp/product/B0BC7W...
Danah AlAwadhi - Reply Share
Hola. What is the part number of the battery?
Javi - Reply Share
Past 24 Hours: 4
Past 7 Days: 39
Past 30 Days: 203
All Time: 12,674
