SPOT X SPOTXB Keyboard Keys Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
40
All Time:
339
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 - 45 minutes
Difficulty: Difficult
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
When some of the keys on your Spot X SpotXB Satellite Messenger keyboard don't work or stick, that defeats the whole point of having one in the first place, blocking your ability to use the device effectively. Well, it's not a problematic replacement to make. This guide will walk you through replacing the keys of your device.
Tools
    1. SPOT X SPOTXB Keyboard Keys Replacement, Back Cover: step 1, image 1 of 3 SPOT X SPOTXB Keyboard Keys Replacement, Back Cover: step 1, image 2 of 3 SPOT X SPOTXB Keyboard Keys Replacement, Back Cover: step 1, image 3 of 3
      • Turn off the device completely by holding the power button for 10-20 seconds to force a shutdown.
      Ask FixBot
    2. SPOT X SPOTXB Keyboard Keys Replacement: step 2, image 1 of 1
      • Remove the seven 4.1 mm screws from the back of the device using a T4 Torx screwdriver.
      Ask FixBot
    3. SPOT X SPOTXB Keyboard Keys Replacement: step 3, image 1 of 1
      • Gently separate the back cover from the rest of the device.
      Ask FixBot
    1. SPOT X SPOTXB Keyboard Keys Replacement, Keyboard Keys: step 4, image 1 of 1
      • Remove the ten 2.9 mm screws from the motherboard using a T5 Torx screwdriver.
      Ask FixBot
    2. SPOT X SPOTXB Keyboard Keys Replacement: step 5, image 1 of 1
      • Remove the faulty keys carefully.
      Ask FixBot
amit
139 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 40
All Time: 339
