SONY SRS-X2 Battery Replacement
Views: 18K
View statistics:
Past 24 Hours:
10
Past 7 Days:
44
Past 30 Days:
183
All Time:
17,986
Comments: 12
7 comments on steps, 5 guide comments.
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Safely take apart the speaker and remove the battery for a replacement.
Tools
    1. SONY SRS-X2 Battery Replacement, Face Plate: step 1, image 1 of 2 SONY SRS-X2 Battery Replacement, Face Plate: step 1, image 2 of 2
      • Use the metal spudger to pry the face screen open. Pull away from the device to remove.
      Ask FixBot
    2. SONY SRS-X2 Battery Replacement: step 2, image 1 of 2 SONY SRS-X2 Battery Replacement: step 2, image 2 of 2
      • Remove seven, 27 mm long Phillips #1 screws.
      • Remove three, 11mm long Phillips #1 screws.
      • Remove four, 10 mm long Phillips#1 screws.
      Ask FixBot
    3. SONY SRS-X2 Battery Replacement: step 3, image 1 of 2 SONY SRS-X2 Battery Replacement: step 3, image 2 of 2
      • Before removing the host plate, face the feet of the speaker to you. The wiring allows for minimal access to the inner components.
      • Use the spudger to remove the speaker host plate. Insert the metal tip in the seam between the host plate and the shell.
      • Be very careful when pulling the speaker host plate (described in the next step) as there are wiring connected to the host plate. This wiring is soldered to the plate and to the shell of the device. The wires are flexible and you can still open the device as shown in the second picture.
      • Center the spudger on the top of the device, this is furthest from the wiring, in wiggling the spudger under the plate, the plate should move up and out of the shell, you can finish lifting the plate away with your fingers.
      Ask FixBot
    4. SONY SRS-X2 Battery Replacement: step 4, image 1 of 2 SONY SRS-X2 Battery Replacement: step 4, image 2 of 2
      • Be gentle when using the opening tool, wiggle the opening tool on each side of the socket to be sure the plastic does not snap.
      • Be careful not to damage the wires, pull from the plastic base to unplug.
      • Unplug the power cable connector shown using the plastic opening tool. Wiggle the tool under the lip of the plug, the smaller area and odd angle means lifting up with the plastic tool in the setup shown.
      • Unplug the power connector shown in the second image. Using the plastic opening tool lift from the front of the plug and move the opening tool to either side to get it all the way out of the socket.
      Ask FixBot
    1. SONY SRS-X2 Battery Replacement, Battery: step 5, image 1 of 2 SONY SRS-X2 Battery Replacement, Battery: step 5, image 2 of 2
      • Remove the four, 11 mm, Phillips#1 screws on the battery cover plate.
      Ask FixBot
    2. SONY SRS-X2 Battery Replacement: step 6, image 1 of 2 SONY SRS-X2 Battery Replacement: step 6, image 2 of 2
      • Remove the battery cover plate carefully then proceed to remove the battery.
      Ask FixBot
13 other people completed this guide.
Yubei Wu
704 Reputation
3 Guides authored
USF Tampa, Team 3-3, Sullivan Fall 2016 Member of USF Tampa, Team 3-3, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G3
4 Members
72 Guides authored
5 Guide Comments
The top two red in the middle and the bottom two orange in the middle are reversed. Other than that the instructions are good.
Ryan Lacharity - Reply Share
THANKS! You are the best!
Gustavo Crescente - Reply Share
Can anyone recommend an online store to buy a battery with the attached cable?
Mario Santos - Reply Share
2400mAh Battery For Sony Bluetooth Wireless Speaker SRS-X2,9-885-197-08,SF-02
https://www.ebay.com/itm/165154920649?ha...
João Arthur Rezende - Reply Share
FYI the original Sony battery cell is a LG ME1 (LGDAME11865) 18650 cell 3.65V 2100mAh rated.
Equivalent to LG ICR18650ME1, 3.6V 2000mAh
Sony's battery labelling says SR7767BP
3.6V / 1950mAh / 7.0Wh
Task514 - Reply Share
Past 24 Hours: 10
Past 7 Days: 44
Past 30 Days: 183
All Time: 17,986
