SONY Ericsson W890i Motherboard Replacement
  1. SONY Ericsson W890i Motherboard Replacement, Battery: step 1, image 1 of 1
    • Flick the two lock tabs into the unlocked positions by pushing each button forward.
    Ask FixBot
  2. SONY Ericsson W890i Motherboard Replacement: step 2, image 1 of 1
    • Pop the back cover up using the groove on the top of the phone.
    Ask FixBot
  3. SONY Ericsson W890i Motherboard Replacement: step 3, image 1 of 1
    • You can now access the phone's battery.
    • Using a spudger, remove the battery and set it aside.
    Ask FixBot
  4. SONY Ericsson W890i Motherboard Replacement, Keypad and Front Cover: step 4, image 1 of 2 SONY Ericsson W890i Motherboard Replacement, Keypad and Front Cover: step 4, image 2 of 2
    • Remove the two small rubber pieces that cover the lower screws.
    • Using a T-6 Torx wrench or screwdriver, remove all four of the small screws at the top and bottom corners on the back of the phones.
    Ask FixBot
  5. SONY Ericsson W890i Motherboard Replacement: step 5, image 1 of 1
    • Gently pry off the faceplate using a plastic opening tool.
    • Insert the plastic opening tool into the middle of the front and back panels of the phone.
    Ask FixBot
  6. SONY Ericsson W890i Motherboard Replacement: step 6, image 1 of 1
    • Separate the front and back panels that were pryed open with the plastic opening tool.
    Ask FixBot
  7. SONY Ericsson W890i Motherboard Replacement, Motherboard: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Now that the faceplate is off, use tweezers to separate the backplate from the inner manifold.
    Ask FixBot
  8. SONY Ericsson W890i Motherboard Replacement: step 8, image 1 of 1
    • With both insides of the phone exposed, gently detach the ribbon cable connecting the two inner sides. You can now separate the two sides of the phone.
    Ask FixBot
  9. SONY Ericsson W890i Motherboard Replacement: step 9, image 1 of 1
    • The motherboard is located on the side with the green and black bumper on the bottom. Use the plastic opening tool to pry the bumper off.
    Ask FixBot
  10. SONY Ericsson W890i Motherboard Replacement: step 10, image 1 of 1
    • To remove the motherboard, apply upwards pressure on the bottom green tab.
    Ask FixBot
Bob
316 Reputation
3 Guides authored
SUNY Cortland, Team 1-3, Getto Spring 2013 Member of SUNY Cortland, Team 1-3, Getto Spring 2013
SUNYCORT-GETTO-S13S1G3
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 54
All Time: 1,389
