SONY Alpha NEX-3N Keypad Replacement
    1. SONY Alpha NEX-3N Keypad Replacement, Getting Started: step 1, image 1 of 2 SONY Alpha NEX-3N Keypad Replacement, Getting Started: step 1, image 2 of 2
      • Remove battery and card
      Ask FixBot
    2. SONY Alpha NEX-3N Keypad Replacement, Back Case 1: step 2, image 1 of 3 SONY Alpha NEX-3N Keypad Replacement, Back Case 1: step 2, image 2 of 3 SONY Alpha NEX-3N Keypad Replacement, Back Case 1: step 2, image 3 of 3
      • Right side, remove 1 M1.4x3.7 screw
      • Left side, remove 3 M1.4x3.7 screws
      • Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
      • Do NOT touch screws on the bottom of LCD assembly.
      Ask FixBot
    3. SONY Alpha NEX-3N Keypad Replacement, Back Case 2: step 3, image 1 of 1
      • Pop the flash.
      • In flash room, remove 1 (one) M1.4x3.8 black screw.
      Ask FixBot
    4. SONY Alpha NEX-3N Keypad Replacement, Back Case 3: step 4, image 1 of 3 SONY Alpha NEX-3N Keypad Replacement, Back Case 3: step 4, image 2 of 3 SONY Alpha NEX-3N Keypad Replacement, Back Case 3: step 4, image 3 of 3
      • Remove LCD hinge cover, by sliding to the left.
      • Remove back cover, actually just a plastic frame.
      Ask FixBot
    5. SONY Alpha NEX-3N Keypad Replacement, LCD assembly: step 5, image 1 of 2 SONY Alpha NEX-3N Keypad Replacement, LCD assembly: step 5, image 2 of 2
      • Remove 1 M1.4x2 screw
      • Remove another M1.4x2 screw, sorry for the angle.
      Ask FixBot
    6. SONY Alpha NEX-3N Keypad Replacement, LCD Assembly: step 6, image 1 of 3 SONY Alpha NEX-3N Keypad Replacement, LCD Assembly: step 6, image 2 of 3 SONY Alpha NEX-3N Keypad Replacement, LCD Assembly: step 6, image 3 of 3
      • CAUTION. Sony makes world's MOST BRITTLE FPC!
      • Loosen LCD assemble with caution!
      • Release FPC cable, the connector is flip type.
      Ask FixBot
    7. SONY Alpha NEX-3N Keypad Replacement, The LCD assembly: step 7, image 1 of 1
      • The LCD assembly
      Ask FixBot
    8. SONY Alpha NEX-3N Keypad Replacement, Dismantle the LCD Part: step 8, image 1 of 3 SONY Alpha NEX-3N Keypad Replacement, Dismantle the LCD Part: step 8, image 2 of 3 SONY Alpha NEX-3N Keypad Replacement, Dismantle the LCD Part: step 8, image 3 of 3
      • After unscrew 4pcs screw you will remove the steel black plate, then slowly pull the black frame there to see the ribbon stripe.
      • Slowly pull the very fragile ribbon lock which i marking with the blue boxes. around just 1mm to unlock the ribbon.. unlucky i broke mine..
      Ask FixBot
    9. SONY Alpha NEX-3N Keypad Replacement, Dismantle the LCD Part: step 9, image 1 of 3 SONY Alpha NEX-3N Keypad Replacement, Dismantle the LCD Part: step 9, image 2 of 3 SONY Alpha NEX-3N Keypad Replacement, Dismantle the LCD Part: step 9, image 3 of 3
      • you can see the ribbon already pull out but be carefull with the others 2 ribbon when your try to pull out this ribbon.
      • the the circle marker that show others ribbon you need to be carefull. goodluck!
      Ask FixBot
    1. SONY Alpha NEX-3N Keypad Replacement, Keypad: step 10, image 1 of 3 SONY Alpha NEX-3N Keypad Replacement, Keypad: step 10, image 2 of 3 SONY Alpha NEX-3N Keypad Replacement, Keypad: step 10, image 3 of 3
      • Lift the keypad.
      • Detach FPC
      Ask FixBot
Terrance
7,063 Reputation
19 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 20
All Time: 339
