Up to 20% off select tools
SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod
Views: 23K
View statistics:
Past 24 Hours:
4
Past 7 Days:
39
Past 30 Days:
222
All Time:
22,553
Comments: 9
6 comments on steps, 3 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Very difficult
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
This guide shows you how to mod your super nintendo region free without a switch and with new LED lights.
btw. This mod doesn't work on 1 Chip SNES or SNES Mini, only works on original 2 Chip SNES. Check for text on the board to confirm your model.
    1. SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, Motherboard: step 1, image 1 of 1
      • Remove the two Phillips two 11.6mm screws that connect the front shield to the motherboard.
      Ask FixBot
    2. SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod: step 2, image 1 of 1
      • Lift the front shield straight up to remove it from the motherboard.
      Ask FixBot
    3. SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod: step 3, image 1 of 1
      • Remove the two silver 15.6 mm Phillips #2 screws on either side of the 62 pin connector.
      Ask FixBot
    4. SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod: step 4, image 1 of 1
      • Remove the 11.8 mm Phillips #2 screw near the rear of the SNES.
      Ask FixBot
    5. SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod: step 5, image 1 of 1
      • Lift the motherboard straight up to remove it.
      Ask FixBot
    1. SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The Two Chips: step 6, image 1 of 1
      • The Two Chips that you need on your Super Nintendo
      • This mod only works on original Super Nintendo with 2 Chips, this mod doesn't work on the 1 Chip Snes.
      Ask FixBot
    2. SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The Lockout Chip: step 7, image 1 of 2 SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The Lockout Chip: step 7, image 2 of 2
      Tool used on this step:
      Desoldering Pump
      $3.99
      Buy
      • Remove the Lock Out chip (use the solder gun)
      • After removing the lock out chip there will probably be leftover of solder where the chip used to be so try to remove the soldier as good as you can
      • To remove the solder leftover, you can use the soldering iron and solder wick.
      Ask FixBot
    3. SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, PPU 2: step 8, image 1 of 2 SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, PPU 2: step 8, image 2 of 2
      • Lift up the PPU2 Pin 30 from the Motherboard
      Ask FixBot
    4. SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, PPU 1: step 9, image 1 of 2 SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, PPU 1: step 9, image 2 of 2
      • Now lift up Pin 24 on PPU 1
      Ask FixBot
    5. SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, Wire Time: step 10, image 1 of 1
      • Wire the lifted pins (PPU 2 Pin 30 & PPU1 Pin 24) together
      • You need to use a Soldering Iron to wire the pins together
      • You can also use tape to hold the wires down to the motherboard
      Ask FixBot
    6. SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, Program: step 11, image 1 of 1
      Ask FixBot
    7. SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The Pins: step 12, image 1 of 3 SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The Pins: step 12, image 2 of 3 SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The Pins: step 12, image 3 of 3
      • Bend the pins outwards
      • Then clip the pins
      • Use double sided tape and put it on top of the CPU and put the Super CIC on top of the double sided tape.
      Ask FixBot
    8. SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The Wires: step 13, image 1 of 3 SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The Wires: step 13, image 2 of 3 SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The Wires: step 13, image 3 of 3
      • Pic 1: Solder a wire from Super CIC Pin 12 to PPU1 Pin 24
      • Pic 2: Solder a wire from Super CIC Pin 14 to SWRAM Pin 64
      • Pic 3: Solder the 10k Ohm Resistor to the pin 8 (where the old CIC used to be) and to SWRAM Pin 33
      Ask FixBot
    9. SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The Wires Part 2: step 14, image 1 of 3 SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The Wires Part 2: step 14, image 2 of 3 SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The Wires Part 2: step 14, image 3 of 3
      • Pic 1: Solder a Wire from Super CIC Pin 1 to 4 on the same chip.
      • Pic 2: Solder a wire from Super CIC Pin 1 to the CPU Pin 1
      • Pic 3: Solder a wire from Super CIC Pin 13 to the End Point of the Resistor
      Ask FixBot
    10. SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The Wires Part 3: step 15, image 1 of 3 SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The Wires Part 3: step 15, image 2 of 3 SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The Wires Part 3: step 15, image 3 of 3
      • Pic 1: Sother a wire from Super CIC Pin 2 to S-CLK Pin 6
      • Pic 2: Sother a wire from Super CIC Pin 11 to Old CIC Pin 10
      • Pic 3: Sother a wire from Super CIC Pin 10 to Old CIC Pin 1
      Ask FixBot
    11. SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The Wires Part 4: step 16, image 1 of 3 SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The Wires Part 4: step 16, image 2 of 3 SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The Wires Part 4: step 16, image 3 of 3
      • Pic 1: Solder a wire from Super CIC Pin 9 to Old CIC Pin 2
      • Pic 2: Solder a wire from Super CIC Pin 8 to Old CIC Pin 11
      • Pic 3: You've soldered most of the wires now, lets go to the LED Mod
      Ask FixBot
    12. SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The LED Mod: step 17, image 1 of 3 SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The LED Mod: step 17, image 2 of 3 SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The LED Mod: step 17, image 3 of 3
      Buy
      • Plug out the controller ports and solder out the LED Light.
      • When the solder points have been desoldered, you can use the tweezers to pull out the led light
      • Sother on the new LED Light with the middle pin on the left solder hole
      • Do Not sother the middle pin on the LED Light to the right solder hole as it will then be stuck in only one color!
      Ask FixBot
    13. SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, Led Resistors: step 18, image 1 of 3 SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, Led Resistors: step 18, image 2 of 3 SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, Led Resistors: step 18, image 3 of 3
      • Solder 2 wires on the left and right pins on the led light, green wire on the left pin and red wire on the right pin.
      • After that you should put the wires into one heat shrink tube each, remember to heat the heat shrink tubes when its over the pins.
      • Then you have to solder the 2k Resistor to the red wire and the 220 ohm Resistor to the green wire.
      • Then the last thing you need to do is to solder a wire from Super CIC Pin 7 to Pin 14.
      Ask FixBot
    14. SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The End: step 19, image 1 of 3 SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The End: step 19, image 2 of 3 SNES 2CHIP 50/60 Hz Switchless Mod + LED Mod, The End: step 19, image 3 of 3
      • You're Now Done! You just need to put your Super Nintendo back together and then you have a Region Free Switchless Super Nintendo!
      • Green Light (PAL)
      • Red Light (NTSC) [For American and Japanese Games]
      • Orange Light (Auto)
      Ask FixBot
These screenshots have been taken by 2 videoes, one from Global Garage and Chips y Bits on YouTube! I made this guide since its a little easier to read a guide with pictures like this instead of watching a 30 min video
3 other people completed this guide.
Author
with
Krisander 1998
668 Reputation
2 Guides authored
3 Guide Comments
Lo hice tal y como dice el tutorial y la snes se quedó con la pantalla negra.
dragonero - Reply Share
Is there some way to get a chip that is already programmed? I don’t have a plan on doing this a lot and the $100 is a bit much at the moment.
Brandon Vanoni - Reply Share
Will this same method be used for the PAL version if the console.
Adrees Sattar - Reply Share
Past 24 Hours: 4
Past 7 Days: 39
Past 30 Days: 222
All Time: 22,553
