SMD resistors organizer
  1. SMD resistors organizer, origami pocket (step1): step 1, image 1 of 3 SMD resistors organizer, origami pocket (step1): step 1, image 2 of 3 SMD resistors organizer, origami pocket (step1): step 1, image 3 of 3
    • cut a square paper
    Ask FixBot
  2. SMD resistors organizer, origami pocket (step2): step 2, image 1 of 3 SMD resistors organizer, origami pocket (step2): step 2, image 2 of 3 SMD resistors organizer, origami pocket (step2): step 2, image 3 of 3
    Ask FixBot
  3. SMD resistors organizer, origami pocket (step2): step 3, image 1 of 3 SMD resistors organizer, origami pocket (step2): step 3, image 2 of 3 SMD resistors organizer, origami pocket (step2): step 3, image 3 of 3
    • continue the pocket
    Ask FixBot
  4. SMD resistors organizer, origami pocket (step2): step 4, image 1 of 2 SMD resistors organizer, origami pocket (step2): step 4, image 2 of 2
    • finish the pocket
    Ask FixBot
  5. SMD resistors organizer, prepare the sheets of values (step1): step 5, image 1 of 3 SMD resistors organizer, prepare the sheets of values (step1): step 5, image 2 of 3 SMD resistors organizer, prepare the sheets of values (step1): step 5, image 3 of 3
    • even sheet with: 10, 12, 15, 18, 22, 27
    • odd sheets with: 33, 39, 47, 56, 68, 82
    • mark the pocket and put tape on long sides
    Ask FixBot
  6. SMD resistors organizer, prepare the sheets of values (step2): step 6, image 1 of 2 SMD resistors organizer, prepare the sheets of values (step2): step 6, image 2 of 2
    • tape the pocket on the right sheet.
    • place the sheet in a usual plastic pocket to prevent the paper pocket to open!
    Ask FixBot
  7. SMD resistors organizer, make sheets for each range of values: step 7, image 1 of 2 SMD resistors organizer, make sheets for each range of values: step 7, image 2 of 2
    • for E12 series, each range of power of 10 can be divided in 2 sheets of 6 pockets.
    • But you can decide to use the same technique to organize E24 resistors, you just need 4 sheets/range.
    Ask FixBot
Flavien Driard
421 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 20
All Time: 313
