Up to 20% off select tools
SHIFT6mq front camera replacement
View statistics:
Past 24 Hours:
8
Past 7 Days:
17
Past 30 Days:
65
All Time:
673
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
Before you start: Make sure that the hardware of your camera is in fact showing defects. The cause of a malfunctioning camera could also be a software error or an unattached connector.
A replacement front camera for your SHIFTPHONE can be bought in the official shop.
Shop
As for tools what you need is a Torx T3 screwdriver and a fingernail, optionally a pick, spudger and tweezers.
The required T3 screwdriver can be found in the original package your SHIFTPHONE came with. Otherwise you can find it in the shop.
nachkaufen
A good helper for this repair is the professionelle Schraubendreher, which comes in a durable metal pouch together with a spudger.
The repair takes around 10 minutes and the workplace should be clean and cleared.
By repairing your SHIFTPHONE you don’t lose out on your warranty, however you must keep in mind any costs that could be caused by a failed repair.
Important: If any step seems not to be possible or too difficult please contact SHIFT before the phone is damaged further. They will provide support.
Kontakt
    1. SHIFT6mq front camera replacement, Preparation: step 1, image 1 of 3 SHIFT6mq front camera replacement, Preparation: step 1, image 2 of 3 SHIFT6mq front camera replacement, Preparation: step 1, image 3 of 3
      • Turn off your SHIFT6mq.
      • Remove the bumper.
      • Use your fingernail (pick/spatula) to detach the back cover at the gap between the frame and the back cover on the bottom left corner (when looking at the back of the phone).
      • Place your finger in the notch, centered under the battery, and lift it out.
      Ask FixBot
    2. SHIFT6mq front camera replacement, Removing the screws: step 2, image 1 of 1
      • Use the T3 screwdriver to loosen all 14 screws. Work your way along the ascending numbering of the screws. This is how you make sure you don't forget any.
      • The rubberized hole in the top center is for the microphone and not a screw.
      • If there is a white seal on the screw, you can easily pierce it with the screwdriver. The positions may vary.
      • All screws in the SHIFT6mq are identical (M1.4 x 3.5). So you can keep them all together in one place.
      Ask FixBot
    3. SHIFT6mq front camera replacement, Remove the Display: step 3, image 1 of 2 SHIFT6mq front camera replacement, Remove the Display: step 3, image 2 of 2
      • Now run your fingernail between the display frame and the middle frame of the SHIFT6mq.
      • If you don't want to do it with your fingernail, you can of course use a pick or spatula.
      • Very gently peel the display along all sides of the phone.
      • The display is still connected to the device! Never pull it off forcefully or more than a few millimeters.
      • If the display is detached from the frame all around, you can go to the next step...
      Ask FixBot
      • Now you can carefully lift off the display, with a slight upward movement to avoid straining the cable.
      • Make sure that there is never any tension on the ribbon cable underneath.
      • Rotate the display around the short, bottom edge. Carefully place the display glass-side down on the SHIFT6mq.
      • If you want to be on the safe side, you can place a sheet of plastic, paper, or an antistatic cloth between the display and the now open phone.
      Ask FixBot
      • Here you can see the motherboard. In the top left you can see the selfie camera facing you.
      • Disconnect the camera connector by inserting the spudger or your fingernail on the left, short side of the connector and prying it off carefully.
      • Be careful not to damage or pry off any near SMD-components
      • Photo: Position of camera, detach grounding strap
      Ask FixBot
      • From the back is a small piece of tape connecting the ground planes of the motherboard and camera.
      • Carefully remove the camera from the phone, pulling it off the adhesive tape from below
      Ask FixBot
      • If the tape is still functional, you can reattach the camera there. Make sure you place it flush against the camera at the top
      Ask FixBot
      • Put the connector on the mainboard and make sure that both parts are completely on top of each other
      • The connector must not be offset at an angle or parallel, as otherwise the contact feet can break off. If it doesn't snap easily, it's probably not positioned correctly
      • When both connectors are properly aligned, press lightly on the connector with a finger. So that you can feel and hear it click into place
      • Pictures: Camera used, connectors on top of each other, finger pressure, connectors correctly plugged in
      Ask FixBot
      • Lay the display on the phone with the screen facing outwards
      • Make sure that the flat ribbon cable of the display never gets any (tensile) load
      • Then press the display along the edge onto the midframe
      • Now you can insert the battery and do a short test run to see if the camera is working properly
      Ask FixBot
      • If everything works properly, turn your SHIFT6mq over and screw all 14 screws back into the holes provided.
      • Make sure that the screws are tight, but without damaging the threads or the screw head. A good guideline is 0.6-0.8 Nm
      Ask FixBot
      • Once all the screws have been reinserted, insert the battery, attach the back cover and pull the bumper over the phone.
      Ask FixBot
Finish Line
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
SHIFTPHONES
1,362 Reputation
7 Guides authored
SHIFT Member of SHIFT
Community
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 17
Past 30 Days: 65
All Time: 673
