Up to 20% off select tools
SHIFT6mq Main Camera Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
16
Past 30 Days:
63
All Time:
642
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Community-Contributed Guide
Needs More Images
A few more images would make this guide's procedures crystal clear.
Parts
Tools
Introduction
Go to step 1 ↓
Before you start: Make sure that it's your camera's hardware that is actually defective. The cause of a non-functioning or poorly functioning camera could also be an error in the software or an incorrectly plugged-in connector.
You can find a new replacement main camera for your SHIFTPHONE in the official SHIFTPHONE Shop.
The tools you need are a Torx T3 screwdriver and your fingernail. Optionally, you can use a pick, spudger and tweezers.
You will find the required T3 screwdriver in the original box of your SHIFTPHONE. It is also available here.
The repair takes about 10 minutes and the workplace should be clean and clear.
Repairing your SHIFTPHONE does not void the warranty. However, you will have to pay for any damage caused by incorrect repairs.
Important: If any step is unusually difficult or something does not come off, please contact SHIFT before major damage occurs. You will get direct support.
    1. SHIFT6mq Main Camera Replacement, Preparation: step 1, image 1 of 3 SHIFT6mq Main Camera Replacement, Preparation: step 1, image 2 of 3 SHIFT6mq Main Camera Replacement, Preparation: step 1, image 3 of 3
      • Turn off your SHIFT6mq.
      • Remove the bumper.
      • Use your fingernail (pick/spatula) to detach the back cover at the gap between the frame and the back cover on the bottom left corner (when looking at the back of the phone).
      • Place your finger in the notch, centered under the battery, and lift it out.
      Ask FixBot
    2. SHIFT6mq Main Camera Replacement, Removing the screws: step 2, image 1 of 1
      • Use the T3 screwdriver to loosen all 14 screws. Work your way along the ascending numbering of the screws. This is how you make sure you don't forget any.
      • The rubberized hole in the top center is for the microphone and not a screw.
      • If there is a white seal on the screw, you can easily pierce it with the screwdriver. The positions may vary.
      • All screws in the SHIFT6mq are identical (M1.4 x 3.5). So you can keep them all together in one place.
      Ask FixBot
    3. SHIFT6mq Main Camera Replacement, Remove the Display: step 3, image 1 of 2 SHIFT6mq Main Camera Replacement, Remove the Display: step 3, image 2 of 2
      • Now run your fingernail between the display frame and the middle frame of the SHIFT6mq.
      • If you don't want to do it with your fingernail, you can of course use a pick or spatula.
      • Very gently peel the display along all sides of the phone.
      • The display is still connected to the device! Never pull it off forcefully or more than a few millimeters.
      • If the display is detached from the frame all around, you can go to the next step...
      Ask FixBot
      • Now you can carefully lift off the display, with a slight upward movement to avoid straining the cable.
      • Make sure that there is never any tension on the ribbon cable underneath.
      • Rotate the display around the short, bottom edge. Carefully place the display glass-side down on the SHIFT6mq.
      • If you want to be on the safe side, you can place a sheet of plastic, paper, or an antistatic cloth between the display and the now open phone.
      Ask FixBot
      • Here you can see the main board. In the middle you can see the dual camera of the SHIFT6mq.
      • An adhesive strip fastenes the ground plane to the camera and the motherboard. Carefully pull this strip off.
      • Your newly delivered replacement camera comes with its own adhesive. A removed adhesive cannot be used again so make sure to use a new one.
      • Photo: Position of camera, Removal of Adhesive
      Ask FixBot
      • Detach the lower camera connector. To do so, insert a spudger or a fingernail on the upper, shorter side of the connector and lift it off.
      • Be careful not to damage or detach any nearby SMD-components.
      • Now remove the upper connector again by introducing the spudger on the shorter side of said connector and lifting it off the board.
      • Now you can carefully remove the dual camera
      • Picture: Positioning of Spudger
      Ask FixBot
      • Carefully place the camera in the mainboard's recess.
      • Put the connector on the socket on the mainboard and make sure that both parts are completely on top of each other.
      • The connector must not be set at an angle or parallel, otherwise the contact pins can break off. If it doesn't snap in easily, it's probably not positioned correctly.
      • When both connections are properly aligned, press lightly on the connector with a finger. You should feel and hear it snap into place.
      • Connect the second connector in the same way.
      • Pictures: inserted camera, connectors on top of each other, finger pressure, correctly plugged in connectors
      Ask FixBot
      • Take the supplied small adhesive tape and stick it over the mainboard shielding and both cameras, as seen at the beginning.
      • Image: gluing process. sticker positioning clearly visible
      Ask FixBot
      • Place the display on the phone with the screen facing outwards.
      • Make sure that the display ribbon cable never gets strained.
      • Press the display along the edge onto the midframe.
      • Now you can insert the battery and do a short test run to see if the camera is working properly.
      Ask FixBot
      • If everything works properly, turn your SHIFT6mq over and screw all 14 screws back into the holes provided.
      • Make sure that the screws are tight, but without damaging the threads or the screw heads. A good guideline is 0.6-0.8 Nm.
      Ask FixBot
      • Once all the screws have been reinserted, insert the battery, attach the back cover and pull the bumper over the phone.
      Ask FixBot
Finish Line
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
SHIFTPHONES
1,362 Reputation
7 Guides authored
SHIFT Member of SHIFT
Community
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 16
Past 30 Days: 63
All Time: 642
