Community-Contributed Guide
Tools
Schraubendreher Torx T3 (Torx T3)
wird mit dem SHIFT6mq ausgeliefert. Nachbstellbar im Shift-Shop
Introduction
Go to step 1 ↓By repairing your SHIFTPHONE you do not lose the warranty. However, you will have to pay for any damage caused by incorrect repairs.
The only tools you need are a Torx T3 screwdriver and your fingernail. You can also use a pick or spatula instead of a fingernail.
A good companion for this repair is the professional screwdriver, which is supplied in a robust metal case together with a practical spatula.
You will find the required Torx T3 screwdriver in the original box of your SHIFTPHONE. Otherwise, you can of course also buy it.
Repairing or opening your SHIFTPHONE does not void the warranty, but you must pay for any costs incurred during or as a result of the repair yourself.
Important: If any step is unusually difficult or something does not want to be solved, please contact us with SHIFT Contact before major damage occurs. There you will receive direct support.
Turn off your SHIFT6mq.
Remove the bumper.
Use your fingernail (pick/spatula) to detach the back cover at the gap between the frame and the back cover on the bottom left corner (when looking at the back of the phone).
Place your finger in the notch, centered under the battery, and lift it out.
Use the T3 screwdriver to loosen all 14 screws. Work your way along the ascending numbering of the screws. This is how you make sure you don't forget any.
Now run your fingernail between the display frame and the middle frame of the SHIFT6mq.
Very gently peel the display along all sides of the phone.
If the display is detached from the frame all around, you can go to the next step...
Now you can carefully lift off the display, with a slight upward movement to avoid straining the cable.
Rotate the display around the short, bottom edge. Carefully place the display glass-side down on the SHIFT6mq.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
