SGIN X15S M.2 SSD Replacement
    1. SGIN X15S M.2 SSD Replacement, Back Panel: step 1, image 1 of 3 SGIN X15S M.2 SSD Replacement, Back Panel: step 1, image 2 of 3 SGIN X15S M.2 SSD Replacement, Back Panel: step 1, image 3 of 3
      • Remove the eight top and middle 7.3 mm screws using the Phillips #0 screwdriver.
      • Remove the six bottom and side 4.4 mm screws using the Phillips #0 screwdriver.
      Ask FixBot
    2. SGIN X15S M.2 SSD Replacement: step 2, image 1 of 3 SGIN X15S M.2 SSD Replacement: step 2, image 2 of 3 SGIN X15S M.2 SSD Replacement: step 2, image 3 of 3
      • Use the nylon spudger to gently pry a bit of the back panel open. With the opening pick, go all the way around until the back panel is loose.
      • Pull the back panel off the laptop.
      Ask FixBot
    1. SGIN X15S M.2 SSD Replacement, Unplugging SGIN X15S Battery: step 3, image 1 of 2 SGIN X15S M.2 SSD Replacement, Unplugging SGIN X15S Battery: step 3, image 2 of 2
      • Gently remove the tape holding the battery's cord to the motherboard, followed by the tape in the middle of the cord.
      • If your battery is swollen, halt this guide and follow the swollen battery disposal guide.
      Ask FixBot
    2. SGIN X15S M.2 SSD Replacement: step 4, image 1 of 3 SGIN X15S M.2 SSD Replacement: step 4, image 2 of 3 SGIN X15S M.2 SSD Replacement: step 4, image 3 of 3
      • Use the nylon spudger to detach the battery from the motherboard.
      Ask FixBot
    1. SGIN X15S M.2 SSD Replacement, M.2 SSD: step 5, image 1 of 2 SGIN X15S M.2 SSD Replacement, M.2 SSD: step 5, image 2 of 2
      • Remove the single 3 mm screw holding the SSD in place using a Phillips #0 screwdriver.
      Ask FixBot
    2. SGIN X15S M.2 SSD Replacement: step 6, image 1 of 3 SGIN X15S M.2 SSD Replacement: step 6, image 2 of 3 SGIN X15S M.2 SSD Replacement: step 6, image 3 of 3
      • Give the SSD a little upward force near the screw side so that it is bent at an angle.
      • Pull the SSD out of its slot.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 55
All Time: 604
