Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓This is how you can easily replace the battery of your SGIN X15S. If the battery is old and no longer holds a charge, this guide is a good solution. While working on your device, if you notice that the battery is swollen, stop your replacement and follow the swollen battery disposal guide. Before working on your device, ensure that it is turned off and completely unplugged from any power sources.
Tools
Spudger4.9
Remove the eight top and middle 7.3 mm screws using the Phillips #0 screwdriver.
Remove the six bottom and side 4.4 mm screws using the Phillips #0 screwdriver.
Gently remove the tape holding the battery's cord to the motherboard, followed by the tape in the middle of the cord.
Using the Phillips #0 screwdriver, remove the three 4.4 mm screws attached to the battery.
Remove the battery.
