SG 552-1 Commando Safety Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
6
Past 30 Days:
41
All Time:
1,150
Comments: 0
Go to guide comments
Completed: 0
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
This guide will be showing step-by-step instructions on how to get to and replace the safety of the airsoft gun.
Tools
    1. SG 552-1 Commando Safety Replacement, Gearbox: step 1, image 1 of 2 SG 552-1 Commando Safety Replacement, Gearbox: step 1, image 2 of 2
      • Using a flathead screwdriver, remove the pin holding the hand guard in place.
      • To remove this, turn the pin clockwise and push it through at the same time.
      • Remove the hand guard.
      Ask FixBot
    2. SG 552-1 Commando Safety Replacement: step 2, image 1 of 2 SG 552-1 Commando Safety Replacement: step 2, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun.
      • There should be four total.
      Ask FixBot
    3. SG 552-1 Commando Safety Replacement: step 3, image 1 of 2 SG 552-1 Commando Safety Replacement: step 3, image 2 of 2
      • Turn the gun over so that you are facing the bottom of the gun.
      • Using a Phillips #1 screwdriver, remove the following screws:
      • Remove the 8mm screw that is located directly underneath the cocking lever.
      • Remove the 8mm screw located beside the screw you just removed.
      Ask FixBot
    4. SG 552-1 Commando Safety Replacement: step 4, image 1 of 2 SG 552-1 Commando Safety Replacement: step 4, image 2 of 2
      • Carefully tug on the tip of the gun and pull the barrel and its cover out.
      Ask FixBot
    5. SG 552-1 Commando Safety Replacement: step 5, image 1 of 3 SG 552-1 Commando Safety Replacement: step 5, image 2 of 3 SG 552-1 Commando Safety Replacement: step 5, image 3 of 3
      • Locate the hand grip.
      • Using a Phillips #0 screwdriver, remove the two 6mm screws at the bottom of the hand grip.
      • Slide the cover off.
      Ask FixBot
    6. SG 552-1 Commando Safety Replacement: step 6, image 1 of 2 SG 552-1 Commando Safety Replacement: step 6, image 2 of 2
      • Pull the motor out of the hand grip.
      • Using a Phillips #1 screwdriver, remove the two 5mm screws inside of the hand grip.
      Ask FixBot
    7. SG 552-1 Commando Safety Replacement: step 7, image 1 of 2 SG 552-1 Commando Safety Replacement: step 7, image 2 of 2
      • Locate the pin holding the folding stock in place.
      • Using an allen wrench or something small, carefully push the pin out.
      Ask FixBot
    8. SG 552-1 Commando Safety Replacement: step 8, image 1 of 2 SG 552-1 Commando Safety Replacement: step 8, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the 20mm screw behind the folding stock and above the gearbox.
      • Remove the cover that was held on by the screw.
      Ask FixBot
    9. SG 552-1 Commando Safety Replacement: step 9, image 1 of 3 SG 552-1 Commando Safety Replacement: step 9, image 2 of 3 SG 552-1 Commando Safety Replacement: step 9, image 3 of 3
      • Using a flathead screwdriver, remove the two 5mm screws beside the safety switch on both sides of the gun.
      • Slide off the piece that was held on by those screws.
      Ask FixBot
    10. SG 552-1 Commando Safety Replacement: step 10, image 1 of 2 SG 552-1 Commando Safety Replacement: step 10, image 2 of 2
      • Using a small allen wrench, carefully unscrew the screws holding the safety switch in place on both sides of the gun.
      • The screws do not have to be taken out all the way, just slightly loosen them until you are able to pull the switch off.
      Ask FixBot
    11. SG 552-1 Commando Safety Replacement: step 11, image 1 of 2 SG 552-1 Commando Safety Replacement: step 11, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the two 6mm screws that were underneath the safety switch on both sides of the gun.
      • Carefully remove the pieces that were held on by the screws.
      Ask FixBot
    12. SG 552-1 Commando Safety Replacement: step 12, image 1 of 3 SG 552-1 Commando Safety Replacement: step 12, image 2 of 3 SG 552-1 Commando Safety Replacement: step 12, image 3 of 3
      • Pull apart the cover when pulling the gearbox out.
      • Pull the gearbox out.
      • The gears will fall out when taking the gearbox out. Careful not to lose them.
      Ask FixBot
    1. SG 552-1 Commando Safety Replacement, Safety: step 13, image 1 of 1
      • Using a Phillips #0 screwdriver, remove the single 3mm screw holding the safety/trigger cover in place.
      Ask FixBot
    2. SG 552-1 Commando Safety Replacement: step 14, image 1 of 2 SG 552-1 Commando Safety Replacement: step 14, image 2 of 2
      • Remove the cover over the trigger.
      • The safety is located underneath the cover.
      Ask FixBot
Anika Morris
1 Reputation
4 Guides authored
Cal Poly, Team 18-41, Regan Fall 2012 Member of Cal Poly, Team 18-41, Regan Fall 2012
CPSU-REGAN-F12S18G41
6 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 41
All Time: 1,150
