SG 552-1 Commando Barrel Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
51
All Time:
2,141
Comments: 0
Go to guide comments
Completed: 0
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide will be showing step-by-step instructions on how to get to and replace the barrel of the airsoft gun.
Tools
    1. SG 552-1 Commando Barrel Replacement, Barrel: step 1, image 1 of 2 SG 552-1 Commando Barrel Replacement, Barrel: step 1, image 2 of 2
      • Using a flathead screwdriver, remove the pin holding the hand guard in place.
      • To remove this, turn the pin clockwise and push it through at the same time.
      • Pull the hand guard off.
      Ask FixBot
    2. SG 552-1 Commando Barrel Replacement: step 2, image 1 of 2 SG 552-1 Commando Barrel Replacement: step 2, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun. There should be four total.
      Ask FixBot
    3. SG 552-1 Commando Barrel Replacement: step 3, image 1 of 2 SG 552-1 Commando Barrel Replacement: step 3, image 2 of 2
      • Locate the button to fold over the folding stock and fold over the folding stock.
      • Using a Phillips #1 screwdriver, remove the 20mm screw located behind the folding stock.
      Ask FixBot
    4. SG 552-1 Commando Barrel Replacement: step 4, image 1 of 2 SG 552-1 Commando Barrel Replacement: step 4, image 2 of 2
      • Turn the gun over so that you are facing the bottom of the gun.
      • Using a Phillips #1 screwdriver, remove the following screws:
      • Remove the 8mm screw located directly underneath the cocking lever.
      • Remove the 8mm screw beside the one you just removed.
      Ask FixBot
    5. SG 552-1 Commando Barrel Replacement: step 5, image 1 of 2 SG 552-1 Commando Barrel Replacement: step 5, image 2 of 2
      • Carefully tug on the tip of the gun and pull the barrel and its cover out.
      Ask FixBot
    6. SG 552-1 Commando Barrel Replacement: step 6, image 1 of 3 SG 552-1 Commando Barrel Replacement: step 6, image 2 of 3 SG 552-1 Commando Barrel Replacement: step 6, image 3 of 3
      • Pull the barrel out from the cover.
      • Remove the pieces at the end of the barrel.
      Ask FixBot
    7. SG 552-1 Commando Barrel Replacement: step 7, image 1 of 2 SG 552-1 Commando Barrel Replacement: step 7, image 2 of 2
      • Remove the remaining pieces of on the ends of the barrel.
      Ask FixBot
Laura Schulz
1 Reputation
1 Guide authored
Cal Poly, Team 18-41, Regan Fall 2012 Member of Cal Poly, Team 18-41, Regan Fall 2012
CPSU-REGAN-F12S18G41
6 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 51
All Time: 2,141
