Up to 20% off select tools
SEGA Genesis Flashback Back Cover Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
23
Past 30 Days:
84
All Time:
1,320
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will help you remove the back cover of your device. You’ll need a Phillips #000 screwdriver to complete this guide.
    1. SEGA Genesis Flashback Back Cover Replacement, Back Cover: step 1, image 1 of 1
      • Scratch off the right-hand side of the sticker at the center of the bottom case using the spudger until the screw is visible.
      • Remove this screw with the Phillips #000 screwdriver.
      Ask FixBot
    2. SEGA Genesis Flashback Back Cover Replacement: step 2, image 1 of 1
      • Remove the two visible screws on the bottom with the Phillips #000 screwdriver.
      Ask FixBot
    3. SEGA Genesis Flashback Back Cover Replacement: step 3, image 1 of 2 SEGA Genesis Flashback Back Cover Replacement: step 3, image 2 of 2
      • Use your fingers to peel off the four corner rubber feet on the bottom.
      • Use the Phillips #000 screwdriver to remove the four screws beneath the rubber feet.
      Ask FixBot
    4. SEGA Genesis Flashback Back Cover Replacement: step 4, image 1 of 1
      • Flip the case to its upright position.
      • Place one hand on the bottom plate of the case and one on the top plate. Gently pull apart the two plates by tilting the top plate about the front of the device. Treat the front of the device as a hinge.
      • Remove the back cover from the device.
      • Be sure not to rip the wire connection of the LED bulb that is still connected to the bottom plate.
      Ask FixBot
Author
with
Viet Nguyen
220 Reputation
2 Guides authored
Cal Poly, Team S24-G12, Maness Spring 2018 Member of Cal Poly, Team S24-G12, Maness Spring 2018
CPSU-MANESS-S18S24G12
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 84
All Time: 1,320
