Introduction
This guide will show you how to replace the suction fan of the dock unit of Roborock's robotic vacuum S7 MaxV Ultra.
I recommend reading the entire guide before starting the disassembly, then following steps as needed during.
Remove the screws using a PH2 screwdriver.
Pull the back cover off.
Disconnect marked connectors from the motherboard.
Remove the zip-tie.
Disconnect the maintenance brush water output tube.
Cut off the ziptie.
Disconnect the tube from the valve.
Remove the marked screw using a PH2 screwdriver.
Push the side panel towards yourself.
Remove the screw using a PH2 screwdriver.
Remove the screw using a PH2 screwdriver, then slide the panel off.
Remove the marked screws using a PH1 screwdriver.
Pull the front cover off. It is still held in place by a couple latches.
Remove the marked screws using a PH2 screwdriver.
Remove the plastic cover.
Remove the rubber cap.
Take the suction fan out.
Pull the foam further down the wires to expose all the connectors, then disconnect those.
Connect the connectors on the new suction fan, then fit the foam over it.
Place it back inside.
When fitting the rubber cap back on, ensure that the suction fan is properly positioned, so that the plastic cover will fit over it.
Once you've done that, reassemble your device.
When putting the halves together, make sure the cables are in their correct grooves.
3 other people completed this guide.
2 Guide Comments
Thank you for this comprehensive guidance
Hvor kan jeg købe en ny motor til min Roborock S7 docking station
