Up to 20% off select tools
Ryobi VC120 Motor Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
100
All Time:
1,676
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Has the motor in your Ryobi VC120 vacuum reached the end of its life? Try replacing it with this guide!
    1. Ryobi VC120 Motor Replacement, Filter: step 1, image 1 of 1
      • Pull the black nose off of the body of the vacuum, by pushing in the orange button closest to the nose.
      Ask FixBot
    2. Ryobi VC120 Motor Replacement: step 2, image 1 of 2 Ryobi VC120 Motor Replacement: step 2, image 2 of 2
      • Grab the filter with two fingers and slide it out.
      Ask FixBot
    1. Ryobi VC120 Motor Replacement, Motor: step 3, image 1 of 2 Ryobi VC120 Motor Replacement, Motor: step 3, image 2 of 2
      • Using a Philips head screwdriver, remove the four screws located on the side panel of the vacuum.
      • There are two types of screws on this device. You may want to use a magnetic screw pad to organize your screws to be sure they return to their designated holes.
      • 4x 19.1mm
      • 1x 14.3mm
      • Once the screws are removed, you should be able to separate the side panel from the rest of the device.
      Ask FixBot
    2. Ryobi VC120 Motor Replacement: step 4, image 1 of 3 Ryobi VC120 Motor Replacement: step 4, image 2 of 3 Ryobi VC120 Motor Replacement: step 4, image 3 of 3
      • Pull your motor out, and remove the black and red cables from the motor by hand.
      Ask FixBot
3 other people completed this guide.
Author
with
Allison Schoch
689 Reputation
4 Guides authored
IUPUI, Team 2-4, Baechle Fall 2015 Member of IUPUI, Team 2-4, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G4
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 100
All Time: 1,676
