Ryobi RS290G Top Cap Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
55
All Time:
394
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your Ryobi RS290G does nothing when you engage the switch trigger, it could be caused by the switch trigger malfunctioning, use this guide to replace your switch trigger.
The switch trigger for the Ryobi RS290G is used to activate the electric motor which then starts orbiting the sandpaper. If the motor does not engage when you push the trigger switch there may be an electrical or mechanical failure, which can accrue from an accidental drop, water damage, or just excess use.
Before starting your switch trigger replacement, make sure power is disconnected.
Tools
    1. Ryobi RS290G Top Cap Replacement, Top Cap: step 1, image 1 of 1
      • Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
      Ask FixBot
    2. Ryobi RS290G Top Cap Replacement: step 2, image 1 of 1
      • Remove the three 16mm Phillips #2 screws from the top cap/upper grip.
      Ask FixBot
    3. Ryobi RS290G Top Cap Replacement: step 3, image 1 of 1
      • Remove the top cap.
      Ask FixBot
Kristen Gismondi
109,798 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 55
All Time: 394
